Compare new / previous string state attribute and extract the difference to include in TTS Message
I have set up a Minecraft Server and have set up a TTS message when players join (and leave using reverse statement) the server using the entity / state sensor.mc_y3_survival_players_online using the following template :
{{ trigger.from_state.state|int < trigger.to_state.state|int }}
What I want to do is use the attribute identified in :
{{ state_attr(‘sensor.mc_y3_survival_players_online’, ‘players_list’)|string }}
And compare the values between from and to values so that :
  • When a player joins I can extract just the added part from the to_state value and feed that to TTS
  • When a player leaves I can extract the removed part from the from_state value and feed that to TTS
Any help would be greatly appreciated !
Since you’re really interested in the players list attribute, trigger off of that instead of having a trigger for each direction of change.
  - platform: state
    entity_id: sensor.mc_y3_survival_players_online
    attribute: players_list
    not_to:
      - none
      - unknown
      - unavailable
    not_from:
      - none
      - unknown
      - unavailable
condition: []
  - variables:
      message: >
        {% set to = trigger.to_state.attributes.players_list %}
        {% set from = trigger.from_state.attributes.players_list %}
        {% if from > to %}
          {{ from | reject('in', to) | first }} has left the game.
        {% else %}
          {{ to | reject('in', from) | first }} has joined the game.
        {% endif %}
  - service: however you TTS
      message: "{{ message }}"
mode: queued
Thanks for the update.
Implemented what you suggested as follows :
alias: "Automation : Notification : Minecraft Survival Player Update"
description: ""
  - platform: state
    not_to:
      - none
      - unknown
      - unavailable
    not_from:
      - none
      - unknown
      - unavailable
condition: []
  - variables:
      message: >
        {% set to = trigger.to_state.attributes.players_list %} {% set from =
        trigger.from_state.attributes.players_list %} {% if from > to %}
        {% else %}
        {% endif %}
  - service: tts.google_translate_say
      entity_id: media_player.bedroom_g_h
mode: queued
But when accessing the MC Server I got the following in the Logs :
2023-01-30 15:25:27.260 ERROR (MainThread) [homeassistant.helpers.event] Error while processing state change for sensor.mc_y3_survival_players_online
  File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 288, in _async_state_change_dispatcher
    hass.async_run_hass_job(job, event)
  File "/usr/src/homeassistant/homeassistant/core.py", line 577, in async_run_hass_job
    hassjob.target(*args)
  File "/usr/src/homeassistant/homeassistant/components/homeassistant/triggers/state.py", line 161, in state_automation_listener
    or not match_to_state(new_value)
  File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 1590, in <lambda>
    return lambda state: invert is not (state in parameter_set)
TypeError: unhashable type: 'list'
2023-01-30 15:25:27.334 ERROR (MainThread) [homeassistant.helpers.event] Error while processing state change for sensor.mc_y3_survival_players_online
I honestly wish I could now add some insight into this, but this is “way above my pay grade and job title” as a “Junior Associate Home Assistant Tinkerer”…
I have however I have figured out that the player_list is formatted as follows (the . (dot) value is a Geyser / Floodgate user) :
Ok, apparently me trying to be ‘smart’ was dumb… the not_to/from breaks it. I added a pair of count filters to the if statement. In testing, it helped make sure both the “leave” and “join” events were announced properly. I also added replace() functions to remove the . you mentioned.
description: ""
  - platform: state
condition: []
  - variables:
      message: >
        {% if from | count > to | count %}
          {{ from | reject('in', to) | first | replace('.', ' ') }} has left the game.
        {% else %}
          {{ to | reject('in', from) | first | replace('.', ' ') }} has joined the game.
        {% endif %}
mode: queued
I have confirmed that the above works… at least when using Alexa as the end point. I don’t use the Google say TTS services, so I can’t really help if that’s the source of any further issues.
You sir are a genius and have made myself, a 49 year adult, and more importantly my 8 year old son happy.
I (we) now have more visibility of when his friends from his whole school year join the servers I have set up for them :+1:
Now you just need to make it so his friends can turn his lights on and off from in-game…
Smart Home Control with MINECRAFT (Home Assistant + Mine Assistant) - YouTube (not actually sure if this still works) :slight_smile:
Ohhh dear…
My servers are papermc and I have luck perms installed too…
One for the weekend :+1:
