Compare time in node red
Greetings!
I am new to home assistant with some very beginner/basic level knowledge about coding.
I am a pilot and hence my schedule is different each day. I have synched my schedule to a google calendar and have integrated the google calendar with home assistant.
the automation I want to achieve in node red is this:
when I leave the zone airport after my duty ends , notify my family that i have left the airport to come home … only when my duty has finished (basically comparing the current time to the attribute ‘duty_endtime’ in the payload (calendar.dharmil_schedule)
the problem I face is that i am not able to compare time (present time with duty end time) . the output of the flow i made is very random … it works sometime and outputs true only when i genuinely leave the airport post my flights but most times it send a false notification as soon as i leave the zone airport/take off irrespective of my duty time not finished
i am not sure if google calendar outputs the ‘duty_endtime’ as a string and i am trying to compare string with current timestamp. please do shed some light on this. i tried learning about comparing times in json but was not so successful
thank you so much you guys for helping this community has really helped and taught me a lot.
PS: sometime i also do 4 flights a day which involves shuttling between to cities like …example departing from 1)paris to rome 2) Rome to paris 3)Paris to milan 4)milan to paris
this is the node red flow i tried using.
[{“id”:“244b74487d24d384”,“type”:“tab”,“label”:“Flow 1”,“disabled”:false,“info”:""},{“id”:“dceb19fbad145dd9”,“type”:“comment”,“z”:“244b74487d24d384”,“name”:“Dharmil leaves home for flight”,“info”:"",“x”:200,“y”:80,“wires”:[]},{“id”:“0383d47d4496b975”,“type”:“ha-zone”,“z”:“244b74487d24d384”,“name”:“dharmil leaves”,“server”:“a1dbb521.14a988”,“version”:0,“exposeToHomeAssistant”:false,“haConfig”:[{“property”:“name”,“value”:""},{“property”:“icon”,“value”:""}],“entities”:[“person.dharmil”],“event”:“leave”,“zones”:[“zone.home”],“x”:111,“y”:219,“wires”:[[“8c285b155029a90e”]]},{“id”:“8c285b155029a90e”,“type”:“api-current-state”,“z”:“244b74487d24d384”,“name”:“roster “,“server”:“a1dbb521.14a988”,“version”:2,“outputs”:1,“halt_if”:””,“halt_if_type”:“str”,“halt_if_compare”:“is”,“entity_id”:“calendar.dharmil_schedule”,“state_type”:“str”,“blockInputOverrides”:false,“outputProperties”:[{“property”:“payload”,“propertyType”:“msg”,“value”:"",“valueType”:“entityState”},{“property”:“data”,“propertyType”:“msg”,“value”:"",“valueType”:“entity”}],“override_topic”:false,“state_location”:“payload”,“override_payload”:“msg”,“entity_location”:“data”,“override_data”:“msg”,“x”:90,“y”:280,“wires”:[[“e34538b4ccda1b61”]]},{“id”:“e34538b4ccda1b61”,“type”:“switch”,“z”:“244b74487d24d384”,“name”:“home base city check”,“property”:“data.attributes.message”,“propertyType”:“msg”,“rules”:[{“t”:“cont”,“v”:“currentcity”,“vt”:“str”}],“checkall”:“false”,“repair”:false,“outputs”:1,“x”:140,“y”:360,“wires”:[[“6d5ab2f433a80cca”]]},{“id”:“6d5ab2f433a80cca”,“type”:“api-current-state”,“z”:“244b74487d24d384”,“name”:“roster”,“server”:“a1dbb521.14a988”,“version”:2,“outputs”:1,“halt_if”:"",“halt_if_type”:“str”,“halt_if_compare”:“is”,“entity_id”:“calendar.dharmil_schedule”,“state_type”:“str”,“blockInputOverrides”:false,“outputProperties”:[{“property”:“payload”,“propertyType”:“msg”,“value”:"",“valueType”:“entityState”},{“property”:“data”,“propertyType”:“msg”,“value”:"",“valueType”:“entity”}],“override_topic”:false,“state_location”:“payload”,“override_payload”:“msg”,“entity_location”:“data”,“override_data”:“msg”,“x”:250,“y”:280,“wires”:[[“fa9bbbf07dd347ee”]]},{“id”:“fa9bbbf07dd347ee”,“type”:“moment”,“z”:“244b74487d24d384”,“name”:“roster date”,“topic”:"",“input”:“data.attributes.start_time”,“inputType”:“msg”,“inTz”:“Asia/Calcutta”,“adjAmount”:0,“adjType”:“days”,“adjDir”:“add”,“format”:“MM/DD/YY”,“locale”:“C”,“output”:“payload”,“outputType”:“msg”,“outTz”:“Asia/Calcutta”,“x”:350,“y”:360,“wires”:[[“e3d2bda22357cddf”]]},{“id”:“e3d2bda22357cddf”,“type”:“switch”,“z”:“244b74487d24d384”,“name”:“date check”,“property”:“globaldate1”,“propertyType”:“global”,“rules”:[{“t”:“eq”,“v”:“payload”,“vt”:“msg”}],“checkall”:“true”,“repair”:false,“outputs”:1,“x”:430,“y”:280,“wires”:[[“3ec4a6d099f12d83”,“7cbbd773200d1c11”]]},{“id”:“93dcac656d680c8a”,“type”:“delay”,“z”:“244b74487d24d384”,“name”:"",“pauseType”:“delay”,“timeout”:“45”,“timeoutUnits”:“minutes”,“rate”:“1”,“nbRateUnits”:“1”,“rateUnits”:“second”,“randomFirst”:“1”,“randomLast”:“5”,“randomUnits”:“seconds”,“drop”:false,“allowrate”:false,“x”:750,“y”:360,“wires”:[[“0ec95988fcbdd06d”]]},{“id”:“3ec4a6d099f12d83”,“type”:“api-call-service”,“z”:“244b74487d24d384”,“name”:“notify”,“server”:“a1dbb521.14a988”,“version”:3,“debugenabled”:false,“service_domain”:“notify”,“service”:“family”,“entityId”:"",“data”:"{“message”:“Dharmil has left home for the airport”}",“dataType”:“jsonata”,“mergecontext”:"",“mustacheAltTags”:false,“outputProperties”:[],“queue”:“none”,“x”:430,“y”:220,“wires”:[[]]},{“id”:“e15de4107b3bbd8a”,“type”:“api-current-state”,“z”:“244b74487d24d384”,“name”:“city check”,“server”:“a1dbb521.14a988”,“version”:2,“outputs”:1,“halt_if”:"",“halt_if_type”:“str”,“halt_if_compare”:“is”,“entity_id”:“sensor.cellphone_geocoded_location”,“state_type”:“str”,“blockInputOverrides”:false,“outputProperties”:[{“property”:“payload”,“propertyType”:“msg”,“value”:"",“valueType”:“entityState”},{“property”:“data”,“propertyType”:“msg”,“value”:"",“valueType”:“entity”}],“override_topic”:false,“state_location”:“payload”,“override_payload”:“msg”,“entity_location”:“data”,“override_data”:“msg”,“x”:1090,“y”:280,“wires”:[[“477f702c61c360b3”,“d1532fcbc313e375”,“5a264e940756c08d”]]},{“id”:“84ff0b57d90ef662”,“type”:“api-call-service”,“z”:“244b74487d24d384”,“name”:“dharmil duty”,“server”:“a1dbb521.14a988”,“version”:3,“debugenabled”:false,“service_domain”:“input_boolean”,“service”:“turn_on”,“entityId”:“input_boolean.dharmil_duty”,“data”:"",“dataType”:“jsonata”,“mergecontext”:"",“mustacheAltTags”:false,“outputProperties”:[],“queue”:“none”,“x”:1350,“y”:280,“wires”:[[]]},{“id”:“477f702c61c360b3”,“type”:“switch”,“z”:“244b74487d24d384”,“name”:“airport”,“property”:“data.attributes.Zones”,“propertyType”:“msg”,“rules”:[{“t”:“cont”,“v”:“airport”,“vt”:“str”},{“t”:“cont”,“v”:“airport 2”,“vt”:“str”}],“checkall”:“true”,“repair”:false,“outputs”:2,“x”:1130,“y”:200,“wires”:[[“84ff0b57d90ef662”,“4eed3d38bbde56f4”],[]]},{“id”:“ab1573faee4a536e”,“type”:“inject”,“z”:“244b74487d24d384”,“name”:"",“props”:[{“p”:“payload”},{“p”:“topic”,“vt”:“str”}],“repeat”:"",“crontab”:"",“once”:false,“onceDelay”:0.1,“topic”:"",“payload”:"",“payloadType”:“date”,“x”:480,“y”:140,“wires”:[[“0ec95988fcbdd06d”,“8c285b155029a90e”]]},{“id”:“d1532fcbc313e375”,“type”:“debug”,“z”:“244b74487d24d384”,“name”:"",“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“true”,“targetType”:“full”,“statusVal”:"",“statusType”:“auto”,“x”:810,“y”:120,“wires”:[]},{“id”:“e7a9d42af06bb59e”,“type”:“comment”,“z”:“244b74487d24d384”,“name”:“Dharmil leaves airport after flight duty”,“info”:"",“x”:190,“y”:440,“wires”:[]},{“id”:“5a264e940756c08d”,“type”:“switch”,“z”:“244b74487d24d384”,“name”:“location check”,“property”:“data.attributes[“Areas Of Interest”]”,“propertyType”:“msg”,“rules”:[{“t”:“cont”,“v”:“airport”,“vt”:“str”}],“checkall”:“true”,“repair”:false,“outputs”:1,“x”:1160,“y”:360,“wires”:[[“f08779f65dfb30df”,“84ff0b57d90ef662”]]},{“id”:“f08779f65dfb30df”,“type”:“api-call-service”,“z”:“244b74487d24d384”,“name”:“notify”,“server”:“a1dbb521.14a988”,“version”:3,“debugenabled”:false,“service_domain”:“notify”,“service”:“mobile_app_cellphone”,“entityId”:"",“data”:"{“message”:“dharmil is at airport and duty turned on “}”,“dataType”:“jsonata”,“mergecontext”:”",“mustacheAltTags”:false,“outputProperties”:[],“queue”:“none”,“x”:1330,“y”:380,“wires”:[[]]},{“id”:“0ec95988fcbdd06d”,“type”:“api-call-service”,“z”:“244b74487d24d384”,“name”:“Location update”,“server”:“a1dbb521.14a988”,“version”:3,“debugenabled”:false,“service_domain”:“notify”,“service”:“mobile_app_cellphone”,“entityId”:"",“data”:"{“message”:“request_location_update”}",“dataType”:“jsonata”,“mergecontext”:"",“mustacheAltTags”:false,“outputProperties”:[],“queue”:“none”,“x”:880,“y”:280,“wires”:[[“e15de4107b3bbd8a”,“d1532fcbc313e375”]]},{“id”:“4eed3d38bbde56f4”,“type”:“api-call-service”,“z”:“244b74487d24d384”,“name”:“notify”,“server”:“a1dbb521.14a988”,“version”:3,“debugenabled”:false,“service_domain”:“notify”,“service”:“mobile_app_cellphone”,“entityId”:"",“data”:"{“message”:“dharmil is at aiport and duty turned on “}”,“dataType”:“jsonata”,“mergecontext”:”",“mustacheAltTags”:false,“outputProperties”:[],“queue”:“none”,“x”:1350,“y”:200,“wires”:[[]]},{“id”:“6f32f1d9fb8c7437”,“type”:“inject”,“z”:“244b74487d24d384”,“name”:"",“props”:[{“p”:“payload”},{“p”:“topic”,“vt”:“str”}],“repeat”:"",“crontab”:"",“once”:false,“onceDelay”:0.1,“topic”:"",“payload”:"",“payloadType”:“date”,“x”:560,“y”:420,“wires”:[[“889aeea9af43fb51”]]},{“id”:“fdf46083fe271af8”,“type”:“delay”,“z”:“244b74487d24d384”,“name”:"",“pauseType”:“delay”,“timeout”:“30”,“timeoutUnits”:“minutes”,“rate”:“1”,“nbRateUnits”:“1”,“rateUnits”:“second”,“randomFirst”:“1”,“randomLast”:“5”,“randomUnits”:“seconds”,“drop”:false,“allowrate”:false,“x”:750,“y”:200,“wires”:[[“0ec95988fcbdd06d”]]},{“id”:“7cbbd773200d1c11”,“type”:“time-range-switch”,“z”:“244b74487d24d384”,“name”:"",“lat”:“19.0999”,“lon”:“72.91737”,“startTime”:“22:30”,“endTime”:“08:30”,“startOffset”:0,“endOffset”:0,“x”:630,“y”:280,“wires”:[[“fdf46083fe271af8”],[“93dcac656d680c8a”]]},{“id”:“dc321b73cf4563ed”,“type”:“ha-zone”,“z”:“244b74487d24d384”,“name”:“left airport”,“server”:“a1dbb521.14a988”,“version”:0,“exposeToHomeAssistant”:false,“haConfig”:[{“property”:“name”,“value”:""},{“property”:“icon”,“value”:""}],“entities”:[“person.dharmil_rao”],“event”:“leave”,“zones”:[“zone.airport”],“x”:100,“y”:520,“wires”:[[“889aeea9af43fb51”]]},{“id”:“889aeea9af43fb51”,“type”:“api-current-state”,“z”:“244b74487d24d384”,“name”:“Dharmil duty”,“server”:“a1dbb521.14a988”,“version”:2,“outputs”:2,“halt_if”:“on”,“halt_if_type”:“str”,“halt_if_compare”:“is”,“entity_id”:“input_boolean.dharmil_duty”,“state_type”:“str”,“blockInputOverrides”:false,“outputProperties”:[{“property”:“payload”,“propertyType”:“msg”,“value”:"",“valueType”:“entityState”},{“property”:“data”,“propertyType”:“msg”,“value”:"",“valueType”:“entity”}],“override_topic”:false,“state_location”:“payload”,“override_payload”:“msg”,“entity_location”:“data”,“override_data”:“msg”,“x”:250,“y”:520,“wires”:[[“d500f2db8f8fca0e”,“45cd1920b9083f8c”],[]]},{“id”:“d500f2db8f8fca0e”,“type”:“api-current-state”,“z”:“244b74487d24d384”,“name”:“Duty end time”,“server”:“969aa5f8.2b8818”,“version”:2,“outputs”:1,“halt_if”:"",“halt_if_type”:“str”,“halt_if_compare”:“is”,“entity_id”:“calendar.dharmil_schedule”,“state_type”:“str”,“blockInputOverrides”:false,“outputProperties”:[{“property”:“payload”,“propertyType”:“msg”,“value”:"",“valueType”:“entityState”},{“property”:“data”,“propertyType”:“msg”,“value”:"",“valueType”:“entity”}],“x”:420,“y”:560,“wires”:[[“02f3c7078d1be484”]]},{“id”:“45cd1920b9083f8c”,“type”:“function”,“z”:“244b74487d24d384”,“name”:"",“func”:“var sidoff=flow.get(‘flowtime’)\nmsg.payload = sidoff\nreturn msg;”,“outputs”:1,“noerr”:0,“initialize”:"",“finalize”:"",“libs”:[],“x”:420,“y”:500,“wires”:[[“3b06018f6e71e20c”]]},{“id”:“02f3c7078d1be484”,“type”:“moment”,“z”:“244b74487d24d384”,“name”:“duty endtime -45 mins”,“topic”:"",“input”:“data.attributes.end_time”,“inputType”:“msg”,“inTz”:“Asia/Calcutta”,“adjAmount”:“45”,“adjType”:“minutes”,“adjDir”:“subtract”,“format”:“DD/MM/YY, h:mm: A”,“locale”:“en”,“output”:“payload”,“outputType”:“msg”,“outTz”:“Asia/Calcutta”,“x”:640,“y”:560,“wires”:[[“3b06018f6e71e20c”,“5b92346a7863a5e6”]]},{“id”:“3b06018f6e71e20c”,“type”:“join”,“z”:“244b74487d24d384”,“name”:"",“mode”:“custom”,“build”:“array”,“property”:“payload”,“propertyType”:“msg”,“key”:“topic”,“joiner”:"\n",“joinerType”:“str”,“accumulate”:false,“timeout”:"",“count”:“2”,“reduceRight”:false,“reduceExp”:"",“reduceInit”:"",“reduceInitType”:"",“reduceFixup”:"",“x”:590,“y”:500,“wires”:[[“70029d602deec642”,“ad302db7a662d86f”]]},{“id”:“ad302db7a662d86f”,“type”:“debug”,“z”:“244b74487d24d384”,“name”:"",“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“true”,“targetType”:“full”,“statusVal”:"",“statusType”:“auto”,“x”:750,“y”:420,“wires”:[]},{“id”:“5b92346a7863a5e6”,“type”:“debug”,“z”:“244b74487d24d384”,“name”:"",“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“true”,“targetType”:“full”,“statusVal”:"",“statusType”:“auto”,“x”:810,“y”:560,“wires”:[]},{“id”:“70029d602deec642”,“type”:“function”,“z”:“244b74487d24d384”,“name”:“Compare Times”,“func”:“newmsg = {};\nif (msg.payload[0] <= msg.payload[1]) {\n newmsg.payload = “True”;\n} else {\n newmsg.payload = “False”;\n}\n\nreturn newmsg;”,“outputs”:1,“noerr”:0,“initialize”:"",“finalize”:"",“libs”:[],“x”:740,“y”:500,“wires”:[[“a04acb108e5eec6e”]]},{“id”:“a04acb108e5eec6e”,“type”:“switch”,“z”:“244b74487d24d384”,“name”:"",“property”:“payload”,“propertyType”:“msg”,“rules”:[{“t”:“eq”,“v”:“True”,“vt”:“str”},{“t”:“eq”,“v”:“False”,“vt”:“str”}],“checkall”:“true”,“repair”:false,“outputs”:2,“x”:890,“y”:500,“wires”:[[“299afda15c512df5”],[“2fb1f2fe4634cf99”]]},{“id”:“299afda15c512df5”,“type”:“api-call-service”,“z”:“244b74487d24d384”,“name”:“Notify Family”,“server”:“a1dbb521.14a988”,“version”:3,“debugenabled”:false,“service_domain”:“notify”,“service”:“family”,“entityId”:"",“data”:"{“message”:“Dharmil has left the airport to come home”}",“dataType”:“jsonata”,“mergecontext”:"",“mustacheAltTags”:false,“outputProperties”:[],“queue”:“none”,“x”:1050,“y”:460,“wires”:[[]]},{“id”:“2fb1f2fe4634cf99”,“type”:“api-call-service”,“z”:“244b74487d24d384”,“name”:“Notify Dharmil “,“server”:“a1dbb521.14a988”,“version”:3,“debugenabled”:false,“service_domain”:“notify”,“service”:“mobile_app_cellphone”,“entityId”:””,“data”:"{“message”:“you have left zone T2 but your duty time is not over”}",“dataType”:“jsonata”,“mergecontext”:"",“mustacheAltTags”:false,“outputProperties”:[],“queue”:“none”,“x”:1060,“y”:540,“wires”:[[]]},{“id”:“143cf7dabd6ef69a”,“type”:“moment”,“z”:“244b74487d24d384”,“name”:“current date & time”,“topic”:"",“input”:"",“inputType”:“msg”,“inTz”:“ETC/UTC”,“adjAmount”:0,“adjType”:“days”,“adjDir”:“add”,“format”:“DD/MM/YY, h:mm: A”,“locale”:“en”,“output”:"",“outputType”:“msg”,“outTz”:“Asia/Calcutta”,“x”:330,“y”:720,“wires”:[[“45342cee28b5f096”]]},{“id”:“933169c416526391”,“type”:“inject”,“z”:“244b74487d24d384”,“name”:"",“props”:[{“p”:“payload”},{“p”:“topic”,“vt”:“str”}],“repeat”:“58”,“crontab”:"",“once”:false,“onceDelay”:0.1,“topic”:"",“payload”:"",“payloadType”:“date”,“x”:110,“y”:720,“wires”:[[“143cf7dabd6ef69a”,“c4d798d51fbb2f6e”,“26f9a6556e3036f6”]]},{“id”:“45342cee28b5f096”,“type”:“function”,“z”:“244b74487d24d384”,“name”:“flowtime”,“func”:“flow.set(“flowtime”,msg.payload);\nreturn msg;\n”,“outputs”:1,“noerr”:0,“initialize”:"",“finalize”:"",“libs”:[],“x”:500,“y”:720,“wires”:[[]]},{“id”:“c4d798d51fbb2f6e”,“type”:“moment”,“z”:“244b74487d24d384”,“name”:“current time”,“topic”:"",“input”:"",“inputType”:“msg”,“inTz”:“ETC/UTC”,“adjAmount”:0,“adjType”:“days”,“adjDir”:“add”,“format”:“h:mm A”,“locale”:“en”,“output”:"",“outputType”:“msg”,“outTz”:“Asia/Calcutta”,“x”:330,“y”:760,“wires”:[[“5d8e4ddf95f8dd9f”]]},{“id”:“5d8e4ddf95f8dd9f”,“type”:“function”,“z”:“244b74487d24d384”,“name”:“flowtimeoff”,“func”:“flow.set(“flowtimeoff”,msg.payload);\nreturn msg;\n”,“outputs”:1,“noerr”:0,“initialize”:"",“finalize”:"",“libs”:[],“x”:510,“y”:760,“wires”:[[]]},{“id”:“6d5726124bbfdf43”,“type”:“comment”,“z”:“244b74487d24d384”,“name”:“For duty end time”,“info”:"",“x”:700,“y”:760,“wires”:[]},{“id”:“2049374feb1dec9f”,“type”:“comment”,“z”:“244b74487d24d384”,“name”:“Date and Time for schedule”,“info”:"",“x”:720,“y”:720,“wires”:[]},{“id”:“26f9a6556e3036f6”,“type”:“function”,“z”:“244b74487d24d384”,“name”:“Global current date “,“func”:“var d = new Date();\nvar options = { timeZone: ‘Asia/calcutta’, year: ‘2-digit’, month: ‘2-digit’, day: ‘2-digit’};\nvar _resultDate = d.toLocaleDateString(‘en-US’, options);\nmsg.payload = _resultDate;\nglobal.set(“globaldate1”,msg.payload);\n//return msg;\n”,“outputs”:1,“noerr”:0,“initialize”:””,“finalize”:"",“libs”:[],“x”:330,“y”:660,“wires”:[[]]},{“id”:“a1dbb521.14a988”,“type”:“server”,“name”:“Home Assistant”,“version”:1,“addon”:true,“rejectUnauthorizedCerts”:true,“ha_boolean”:“y|yes|true|on|home|open”,“connectionDelay”:true,“cacheJson”:true},{“id”:“969aa5f8.2b8818”,“type”:“server”,“name”:“Home Assistant”,“version”:1,“legacy”:false,“addon”:true,“rejectUnauthorizedCerts”:true,“ha_boolean”:“y|yes|true|on|home|open”,“connectionDelay”:true,“cacheJson”:true}]
Not sure this helps. You can use the calendar state as a condition or trigger or both. When there’s an event going on, it stays on. As soon as the event ends, the calendar goes off.
The json is invalid. There is a date and time format node that could make the conversion. There are also a ton of additional sensors in the phone app. Bottom of the side menu → app settings → manage sensors. Take a look at geocoded location.
Between that and device tracker attributes, like altitude. Calculation of distance traversed. Set a zone larger than the airports that if you break it in a minute or 2 you’ll know you’re traveling +100mph. There should be a value you can use to tell if you’re in a plane or a car.
If your car has bluetooth or get a tile. That connection to your phone app can be monitored.
Thank u so much for your replies !! I tried the export flow in node red and opt pasted the flow , I wonder what mistake I made there coz of which the json code is invalid.
Anyway so I do use the geo coded location from my phone and also use the attribute like area of interests etc to try and check if I genuinely left the airport
The calendar state will be ‘on’ on days when I land early so that I ain’t sure if it would work seamlessly without any further intervention by me every now and then
So thought of turning an input Boolean on when my duty time comes to and end
And when I leave the zone airport , it will send notification only if the Boolean is on
But was looking for a cleaner way to do it
Thanks again
Pls do let me know how can I upload My flow here
I think all you need is the second zone, as long as you live more than 5 minutes from the airport. You could use something really simple like:
And create 2 zones like this around your home airport.
