Hello, I know there are many topics discussing unix timestamp conversions already, but I didn’t find the information I need for my purpose. I sucsessfully used the homeassistant-googletokenretriever from @chvancooten to get the next alarm from my Google Home Mini into Home Assistant.
It’s in the unix format (for example “1612944005000.0”). I now need a way to compare that timestamp to the actual time and trigger an action of some type to slowly dim my lights. I hope someone can help me.
What entity is your timestamp stored in?
It should be a sensor entity. The configuration looks like this:
platform: command_line
command: "curl --insecure --header \"cast-local-authorization-token: {{ state_attr('input_text.google_tokens', 'token_my-google-home') }}\" https://my-google-home:8443/setup/assistant/alarms"
value_template: >
{% set alarms = value_json.alarm|sort(attribute='fire_time') %}
{% if alarms[0] is defined %}
{{ alarms[0].fire_time }}
{% else %}
None
{% endif %}
Ok you could try this:
platform: template
value_template: "{{ states('sensor.next_alarm') | int - as_timestamp(now()) < 30*60 }}"
Or maybe as_timestamp(utcnow())
, check in the developer tools template editor.
Thank you, the second one worked!
Hi @tom2199! Great to hear my script is useful
Looks like your question was answered, I also use something similar to show the alarm time in my interface. Additionally, I have the following binary sensor that checks if the alarm is (less than) 15 minutes away in order to trigger my wakeup light automation. Maybe it’s helpful
sensors:
next_alarm_within15min:
value_template: >
{% if states('sensor.next_alarm') == "None" or states('sensor.next_alarm') == "unavailable" or states('sensor.next_alarm') == "unknown" %}
False
{% else %}
{{ (states('sensor.next_alarm') | int / 1000) - (as_timestamp(states('sensor.date') ~ ' ' ~ states('sensor.time')) | int) < 990 }}
{% endif %}
friendly_name: Next alarm within 15 minutes
icon_template: 'mdi:alarm'
delay_on:
seconds: 90
Quite ugly, but it works!
Thank you for your script! And thanks for chiming in, I appreciate it!
