Hi, I have just started using Home Assistant and I have a custom controller that I would like to add.
The following configuration works perfectly:
switch:
platform: command_line
switches:
room_light:
command_on: "/usr/bin/curl -s -o /dev/null -X GET <URL>“
command_off: "/usr/bin/curl -s -o /dev/null -X GET <URL>”
command_state: "/usr/bin/curl -s -X GET <URL>”
value_template: '{{ value == "1" }}'
friendly_name: "Room Light"
but its supposed to be a light switch so I tried replicating it using template light and I can’t figure out how to make the value_template to work. This is what I have so far and the on / off works fine its updating the current value that doesn’t.
shell_command:
wib_out_3_1: "/usr/bin/curl -s -o /dev/null -X GET <URL>“
wib_out_3_0: "/usr/bin/curl -s -o /dev/null -X GET <URL>"
wib_out_3_t: "/usr/bin/curl -s -o /dev/null -X GET <URL>"
wib_pin_3: "/usr/bin/curl -s -X GET <URL>"
light:
lights:
room_light:
value_template: '{{ shell_command.wib_pin_3 == "1" }}'
turn_on:
- service: shell_command.wib_out_3_1
# data:
# entity_id: switch.kitchen_lights
turn_off:
- service: shell_command.wib_out_3_0
# data:
wib_pin_3 is supposed to return the same get request as command_state which is 1 for on and 0 for off. No JSON or anything just a single char. What am I doing wrong with the value_template?
