I want to parse a telegram command which contains the operation to perform.
It can be either ‘on’ or ‘off’.
Using .split
i’m able to parse the operation string and I have a variable containing it.
However, no matter what I do, the comparison to ‘on’ or ‘off’ fails.
Example command: /light_action_main_op_on
Here is the code:
- service: script.turn_on
data_template:
entity_id: >
{% set tokens = trigger.event.data['data'].split('/light_action_') %}
{% set tokens = tokens[1].split("_op_") %}
{% set operation = tokens[1] %}
{% if operation == 'on' %}
script.turn_on_light
{% elif operation == 'off' %}
script.turn_off_light
{% else script.dummy %}
script.dummy_script
{% endif %}
I’ve tried printing the operation
and it’s indeed on
/off
(with no whitespaces).
What am I missing?
