Is there a way to flip the W and E so If you rotate the compass to the direction your house is facing they will render correctly?
Itās on my to-do list
Great, thanks for all the work, on your time on this. I really appreciate it.
1 More question. Iām trying to self educate on this and see some compass cards have removed the top direction heading that is auto generated. The W for west in my image above. Do I use card mod to remove that? I havenāt been able to fing, or more likely I overlooked an example someone has posted where that has been done specifically or it was just part of there mod where they were showing something else?
Iām not quite sure what you mean to achieve.
Could you provide an example mock-up image (e.g. done in paint)?
I figured it out, be reading the thread again and messing with it. Just have to edit the HTML to get the display how I want.
Thanks for the reply
@tomvanswam, I am very grateful for your compass card and have incorporated it into dashboards intended for use on a sailboat, as seen here. Node-RED has made it feasible to get data from the NMEA data bus with which all modern instruments communicate, and HA is proving a very versatile platform to display and log everything.
I wonder if you would consider a rather unique use case: Apparent Wind Angle, AWA.
When sailing, wind direction is presented in two ways: 1) True Wind Angle as a 360 degree compass direction and 2) Apparent Wind Angle relative to the direction of travel as 0-180 degrees Left or Right. Typically looks like this.
Presently, I am converting True Wind Angle to a 0-360 number to make it compatible with your compass card. When the direction is Right, I pass the sensor value. When the direction is Left, I pass 360-sensor.value.
Also, has there been any discussion about adding a sensor.device.class for compass direction in HA?
Thanks for the kind words and a screenshot of how youāre using the card.
Someone already opened a feature request also related to a nautical usecase. So you could add another feature request for this second nautical usecase. It wonāt be at the top of my list, but when I get to it Iāll implement it.
It might take some time to get to this though, as there is quite a backlog of other bugfixes and features for me to work on, and only so little time.
I didnāt hear anything about a sensor class for cardinal directions, but then again, Iām also not keeping track on that.
I would love to see a screenshot of your solution and think of a way to configure what you want, instead of tweaking HTML.
Astroweather integration adds a moon azimuth sensor.
Just to follow up on my post. Using the Astroweather integration I have added the moon position so I now can see both. It looks like this and the YAML is below.
type: custom:compass-card
indicator_sensors:
- sensor: sun.sun
attribute: azimuth
indicator:
type: circle
color: orange
dynamic_style:
sensor: sun.sun
attribute: elevation
bands:
- from_value: 0
show: true
- sensor: sensor.astroweather_moon_azimuth
indicator:
type: circle
color: black
dynamic_style:
sensor: sensor.astroweather_moon_phase
bands:
- from_value: 0
show: true
value_sensors:
- sensor: sun.sun
units: Ā°
decimals: 1
compass:
circle: null
north:
show: true
color: red
east:
show: true
west:
show: true
south:
show: true
Hi, I send data from my windmeter via MQTT to HA.
When I try to use the compass card, the arrow does not move.
What am I doing wrong?
I think you should remove the attribute: azimuth
line.
If that does not work, please post the result of the Developer Tools ā States Tab page, when filtering on sensor.meteo_wind_richting
. Then I can see if the format of the sensor or one of its attributes could be used for the indicator sensor.
Dank je Tom.
The removal of azimuth worked!
Hi Tom, would you like to share your background imges that you use in your theme?
It looks really nice!
Sorry I have not used background images for a while and I no longer have them. Now I use a gradient fill instead.
I kept them for debugging puroses.
You can find them here:
Dashboard background day
Per card background day
Dashboard background night
Per card background night
And config files for the themes:
Day theme
Night theme
Disclamer, I havent checked the correct working of the theme yaml files for some time, so they might be broken with current Home Assistant version or Card-Mod version.
What card are you using for your graphing data?
Thank you!
