Compass Card - Points you in the right direction šŸ§­
I wondered about that. But the card should be able to fix this as well. No one shows the degree symbol like that.
if the card accepts selectors then try one of the 2 I posted in the previous message
It looks like thisā€¦ no idea what I should enter to fix it (I inspected the degree symbol)
@petro is correct, due to the difference in font-size the degrees symbol is halfway up the value.
This is intentional, as this is the same for other sensor cards:
192.168.2.50_8123_lovelace_test (8)
With card-mod you can change the styling of the card to your liking.
Instead of making the degrees symbol larger, you could make the elevation smaller:
style: |
  .sensor-1 {
    line-height: 18px;
  .sensor-1 .value {
    font-size: 18px !important;
You get this result:
192.168.2.50_8123_lovelace_test (7)
Or make the degrees symbol larger with this yaml:
style: |
  .sensor-1 .measurement {
    font-size: 28px !important;
And this result:
192.168.2.50_8123_lovelace_test (9)
As you can see I only changed the look of the second value, this is possible with v1.0.0-alpha2 and higher.
For css reference:
  • All indicator-values (the NW) are wrapped in a indicator-sensors class
  • Each separate indicator value line is wrapped in a sensor-x class, with x beeing the index of the sensor
    • 0 for first sensor displayed, 1 for second and so on.
  • Each separate indicator-sensor line is divided in 3 parts, with each its own class
    • abbreviation part with class abbr
      • only the first indicator-sensor has its values shown by default, if you wish to enable this for the next indicator entities, add for each indicator-sensor you want to show
        state_abbreviation:
          show: true
    • value part with class value
      • value is hidden by default, if you wish to show the value for a sensor add the following to your yaml
        state_value:
          show: true
    • units part with class measurement
      • Measurement is the odd one, but the ha vanilla sensor-card also uses measurement for the units
      • units are hidden by default, if you wish to show the value for a sensor add the following to your yaml
        state_units:
          show: true
  • All value-sensor values are wrapped in a value-sensors class
  • Each separate value-sensor value line is wrapped in a sensor-x class, with x beeing the index of the sensor
  • Each separate value line is divided in 2 parts, with each its own class
Actually itā€™s not the same in any other card and itā€™s not any kind of standard. (I am a Land Surveyor by training)
Iā€™ll try the suggested css to correct this but it shouldnā€™t be necessary.
Youā€™re correct, not all cards show the units in smaller font.
The entities-card shows the units same font-size as the value:
192.168.2.50_8123_lovelace_test (13)
However Iā€™m trying to keep the compass-card default layout as close to the default sensor-card (top-left) as possible and this also has a smaller font for the units (unless my dev env is broken).
None of these doā€¦
None of those do and itā€™s not any kind of standard I am aware of (outside a sensor/entity card apparently)
Beta 1 for v1.0.0 is out. :rocket:
The dynamic styling is working now.
I tried to write up an example on how to configure it: https://github.com/tomvanswam/compass-card/tree/v1.0.0-beta1#dynamic-style--style-band-example
If you have any questions, just ask.
Hi Tom, what am I doing wrong?
Not seeing the indicator change colour with this config:
type: 'custom:compass-card'
indicator_sensors:
  - sensor: sensor.bom_hobart_wind_direction
    dynamic_style:
      sensor: sensor.bom_hobart_wind_speed_kt
      bands:
        - from_value: 0
          color: '#039BE5'
        - from_value: 10
          color: '#0da035'
        - from_value: 20
          color: '#e0b400'
        - from_value: 30
          color: '#e45e65'
value_sensors:
  - sensor: sensor.bom_hobart_wind_speed_kt
compass:
  north:
    show: true
header:
  title:
    value: Wind Direction
I can get the north symbol to change colour with a similar config, but that is not what Iā€™m after.
Hi @tom_l , the dynamic_style for the indicator is in a indicator object like this:
indicator_sensors:
    indicator: # add this level to change the indicator
      dynamic_style:
        bands:
          - from_value: 0
            color: '#039BE5'
          - from_value: 10
            color: '#0da035'
          - from_value: 20
            color: '#e0b400'
          - from_value: 30
            color: '#e45e65'
Edit: corrected yaml example
Close, I had to indent sensor and bands under dynamic_style too.
class: top-level-graph
indicator_sensors:
    indicator:
      dynamic_style:
        bands:
          - from_value: 0
            color: '#039BE5'
          - from_value: 10
            color: '#0da035'
          - from_value: 20
            color: '#e0b400'
          - from_value: 30
            color: '#e45e65'
value_sensors:
compass:
  north:
    show: true
header:
  title:
Ah, I was struggeling with the copy paste of your example so I did mess up the indenting :frowning:
Itā€™s a great card. Thanks!
How can I adjust the compass card height to match the height of other cards (to match the cards on either side)? See screenshot. (FYI, Iā€™m using the V1.0.0-beta1)
I will answer my own question. Install ā€œcard-modā€ from HACS and add the following style to the card:
style: 'ha-card { height: 100%; }'
Hi, wanting to use this card but struggling to get it to show up. Trying to follow steps in Manual:-
1&2) Looks to have downloaded OK to default location - /config/www/community/compass-card
  1. I donā€™t have Lovelace Dashboards in my Config folder.
Seems a basic omission but begs potentially silly questions as to why & how to best rectify?
TIA
You can find the lovelace dashboard in the configuration menu in home assistant gui. From step 3 on everything is done on the webpages itself.
Thanks for replying. I was looking in File Editor, of course. Your download was next to another downloaded card yet wasnā€™t appearing in the cards, unlike the other.
Restarting and looking at it again in the light of day seems to have resolved it!
Why i donā€™t get the sun elevation unit in the card?
Schermata 2020-11-15 alle 16.31.05
This is my card:
      - type: custom:compass-card
        header:
          title:
            value: Wind Direction & Sun
        indicator_sensors:
          - sensor: sensor.cc_climacell_wind_direction_0h
            indicator:
              dynamic_style:
                sensor: sensor.cc_climacell_wind_speed_00m
                bands:
                  - from_value: 0
                    color: '#039BE5'
                  - from_value: 10
                    color: '#0da035'
                  - from_value: 20
                    color: '#e0b400'
                  - from_value: 30
                    color: '#e45e65'
              type: arrow_inward
          - sensor: sun.sun
            attribute: azimuth
            indicator:
              type: circle
        value_sensors:
          - sensor: sensor.cc_climacell_wind_speed_00m
          - sensor: sun.sun
            attribute: elevation
        compass:
          north:
            show: true
            offset: 0
What is your background for that ? and how have you done it ? :slight_smile:
