Compatibility of Klarstein AC devices and Gree Integration
So, I brought my Klarstein AC via Klarstein App in my WiFi environment and can control it with the app. But I can’t get it into HA.
I installed as described, but i cant see my Klarstein A/C.
Device is in the same environment as HA. It seems in the logs, that it recognizes all data but than an error occurred.
Is it the same with you?
@VB_Master can you paste your logs? Where do they differ?
6-30 23:17:44.307 INFO (MainThread) [custom_components.gree.climate] Setting up Gree climate platform
2023-06-30 23:17:44.308 INFO (MainThread) [custom_components.gree.climate] Adding Gree climate device to hass
2023-06-30 23:17:44.308 INFO (MainThread) [custom_components.gree.climate] Initialize the GREE climate device
2023-06-30 23:17:44.308 INFO (MainThread) [custom_components.gree.climate] Retrieving HVAC encryption key
2023-06-30 23:17:44.317 INFO (MainThread) [custom_components.gree.climate] Fetching(192.168.xx.xx, 7000, 10, {“cid”: “app”,“i”: 1,“pack”: “xxx”,“t”:“pack”,“tcid”:“xxx”,“uid”: 0})
2023-06-30 23:17:54.349 ERROR (MainThread) [homeassistant.components.climate] Setup of platform gree is taking longer than 60 seconds. Startup will proceed without waiting any longer.
Logger: homeassistant.components.climate
First occurred: 30. Juni 2023 um 23:17:54 (1 occurrences)
Last logged: 30. Juni 2023 um 23:17:54
