EDIT: this is working now - it just needed a minute! working great on 4ie models. thank you
So i was able to ssh into my HA and git clone to custom_componants etc
followed install instructions but the addon is not loading (even after restarting and adding climate to the config)
I do get the error in logs: 2022-08-29 05:52:00.978 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration warmup which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
For any Warmup 6IE owners out there, I just wanted to let you know that ha-warmup works perfectly and I now have control as well as being able to see the air temp and floor temp. Many thanks to @foxy82 for the work on this.
Andrew.
Is this project still active? I have Laticrete Strata Heat thermostats which are just rebranded warmup. I added the thermostat to the warmup app successfully, but I get an error when I try to connect to the repo. Looking in the logs, I was getting a status 200, which would indicate success, but I added some debugging to the logs to get more info. I have verified that the username/password combination is correct, as well (again, through debugging statements). Iâm a little bit out of my element and could use some assistance decoding this error.
Hey,
I am trying to Install Warm-up, but not sure, what am I doing wrong. Newbie with Home Assistant.
Installation in HACS work well. I see that Integration there. I add username and password to my configuration.yaml But after restarting home assistant, the component is not loaded automatically. I canÂŽt add new Device or Integration. I get this: You can add this device by adding it to your âconfiguration.yamlâ. See the documentation for more information.
How it should be done?
Thank you for any help
I am having a similar problem I have added the custom component and can see it, I have also added an entry to my configuration.yaml file, but there are no devices available.
I have two warm 4ies working still but am adding another room with undertile heating - however it seems you canât really buy these anymore (I am trying to import to Australia)
Can anyone recommend any others that work with HA? thank you
