I am running Home Assistant in Docker on an Intel NUC for many years. It has no built in bluetooth support, so I bought a ROLIO BT5.3 USB bluetooth stick. Home Assistant saw the device, but it could not set up the bluetooth integration without an error. I think the USB device I used might not be the right type. Has enyone reccomendations?
not yet, that might be an option!
The ESP32s you can get quite cheap at aliexpress.
Did you forward dbus to the container?
