Hi
I try to build a sketch to do a clock with LED rings. Here is code below that I used and after the error while compiling. Any ideas what’s wrong there ? If code is validated it should compile no ? Just for infos I have already compiled few esp sketches before so I know my ESPHome setup is good (running 1.14.3).
Thanks for your ideas
Vincèn
Sketch for ESPHome:
esphome:
platform: ESP8266
board: d1_mini
on_boot:
priority: -10
then:
# enable clock effect after boot
- light.turn_on:
brightness: 50%
effect: Clock
wifi:
ssid: "Mywifi"
password: "Mypasswd"
web_server:
# Enable Home Assistant API
api:
ota:
globals:
- id: clock_brightness
type: int
restore_value: yes
initial_value: '255'
- id: clock_indicators_enabled
type: bool
restore_value: yes
initial_value: 'true'
- id: clock_seconds_enabled
type: bool
restore_value: yes
time:
- platform: homeassistant
switch:
name: "Clock Indicators"
icon: mdi:progress-clock
lambda: !lambda |-
return id(clock_indicators_enabled);
turn_on_action:
globals.set:
value: 'true'
turn_off_action:
globals.set:
value: 'false'
icon: mdi:update
lambda: !lambda |-
return id(clock_seconds_enabled);
turn_on_action:
globals.set:
value: 'true'
turn_off_action:
globals.set:
value: 'false'
light:
- id: light_ring
internal: False
platform: fastled_clockless
rgb_order: GRB
chipset: WS2811
pin: D5
num_leds: '24'
color_correct: [90%, 90%, 90%]
effects:
- lambda:
update_interval: 32ms
lambda: |-
static boolean initialized;
static ESPColor clock_ring_colors [60];
if (initialized == false) {
std::fill_n(clock_ring_colors, it.size(), ESPColor::BLACK);
initialized = true;
auto time = id(sntp_time).now();
if (!time.is_valid()) {
return;
// calculate led indices
int second_idx = (int) (time.second * (it.size() / 60));
int minute_idx = (int) (time.minute * (it.size() / 60));
int hour_idx = (int) ((time.hour % 12) * (it.size() / 12));
int hour_inc_min_idx = hour_idx + (int) (((float) time.minute / 12) * (it.size() / 60));
// fade out old colors
for (int i = 0; i < it.size(); i++) {
ESPColor old_color = clock_ring_colors[i];
// fade out color
int amount = 5;
int red = old_color.red;
int green = old_color.green;
int blue = old_color.blue;
int white = old_color.white;
if (red < amount) { red = 0; } else { red -= amount; }
if (green < amount) { green = 0; } else { green -= amount; }
if (blue < amount) { blue = 0; } else { blue -= amount; }
ESPColor new_color = ESPColor(red, green, blue, 0);
clock_ring_colors[i] = new_color;
int indicator_brightness = id(clock_brightness) / 3;
ESPColor indicator_color = ESPColor(indicator_brightness, indicator_brightness, indicator_brightness);
// calculate colors
ESPColor second_color = ESPColor(id(clock_brightness), 0, 0);
ESPColor minute_color = ESPColor(0, id(clock_brightness), 0);
if (minute_idx == second_idx) {
minute_color += second_color;
ESPColor hour_color = ESPColor(0, 0, id(clock_brightness));
if (hour_inc_min_idx == minute_idx) {
// if seconds are also the same this will already contain the second color
hour_color += minute_color;
} else if (hour_inc_min_idx == second_idx) {
hour_color += second_color;
if (id(clock_indicators_enabled)) {
for (int i = 0; i < it.size(); i += (int) ((float) it.size() / 12)) {
clock_ring_colors[i] = indicator_color;
// set colors
if (id(clock_seconds_enabled)) {
clock_ring_colors[second_idx] = second_color;
clock_ring_colors[minute_idx] = minute_color;
clock_ring_colors[hour_inc_min_idx] = hour_color;
// apply colors to light
it[i] = clock_ring_colors[i];
- addressable_rainbow:
speed: 8
width: 24
speed: 3
width: 24
- random:
transition_length: 30s
update_interval: 30s
Compilation log:
INFO Reading configuration /config/esphome/rgb_ring.yaml...
INFO Detected timezone 'CET' with UTC offset 1 and daylight savings time from 28 March 02:00:00 to 31 October 03:00:00
INFO Generating C++ source...
INFO Compiling app...
INFO Running: platformio run -d /config/esphome/rgb_ring
Processing rgb_ring (board: d1_mini; framework: arduino; platform: [email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
Dependency Graph
|-- <ESPAsyncTCP-esphome> 1.2.2
| |-- <ESP8266WiFi> 1.0
|-- <ESPAsyncWebServer-esphome> 1.2.6
| |-- <Hash> 1.0
| |-- <ArduinoJson-esphomelib> 5.13.3
|-- <ESP8266mDNS> 1.2
|-- <FastLED> 3.2.9
| |-- <EspSoftwareSerial> 5.0.4
Compiling /data/rgb_ring/.pioenvs/rgb_ring/src/main.cpp.o
src/main.cpp: In lambda function:
src/main.cpp:358:40: error: 'it' was not declared in this scope
src/main.cpp:366:46: error: 'it' was not declared in this scope
*** [/data/rgb_ring/.pioenvs/rgb_ring/src/main.cpp.o] Error 1
========================== [FAILED] Took 4.13 seconds ==========================
