Compile error in systemctl environment.How to resolve.
/etc/systemd/system/esphome.service
[Unit]
Description=esphome
after=network.target
[Service]
Type=simple
User=pi
WorkingDirectory=/opt/esphome
ExecStartPre=source /home/pi/homeassistant/bin/activate
ExecStart=/home/pi/homeassistant/bin/python /home/pi/homeassistant/bin/esphome config/ dashboard
RestartSec=30
Restart=on-failure
Environment=“PATH=/home/pi/homeassistant/bin:/usr/local/sbin:/usr/local/bin:/usr/bin”
[Install]
WantedBy=multi-user.target
ESPHOME Compile log:
INFO Reading configuration config/watherTheFlowers.yaml…
INFO Detected timezone ‘CST’ with UTC offset 8
INFO Generating C++ source…
INFO Compiling app…
INFO Running: platformio run -d config/wathertheflowers
Processing wathertheflowers (board: nodemcuv2; framework: arduino; platform: [email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
PACKAGES:
- framework-arduinoespressif8266 2.20502.0 (2.5.2)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.20600.0 (2.6.0)
- toolchain-xtensa 2.40802.200502 (4.8.2)
Dependency Graph
|-- 1.2.2
| |-- 1.0
|-- 1.0
|-- 1.2
| |-- 1.0
|-- 0.8.4
| |-- 1.2.2
| | |-- 1.0
|-- 5.13.3
Compiling .pioenvs/wathertheflowers/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/wathertheflowers/src/esphome/components/api/api_pb2.cpp.o
Compiling .pioenvs/wathertheflowers/src/esphome/components/api/api_pb2_service.cpp.o
*** [.pioenvs/wathertheflowers/src/esphome/components/api/api_connection.cpp.o] sh: No such file or directory: ‘sh’
Compiling .pioenvs/wathertheflowers/src/esphome/components/api/api_server.cpp.o
*** [.pioenvs/wathertheflowers/src/esphome/components/api/api_pb2.cpp.o] sh: No such file or directory: ‘sh’
*** [.pioenvs/wathertheflowers/src/esphome/components/api/api_pb2_service.cpp.o] sh: No such file or directory: ‘sh’
*** [.pioenvs/wathertheflowers/src/esphome/components/api/api_server.cpp.o] sh: No such file or directory: ‘sh’
========================= [FAILED] Took 15.72 seconds =========================
