I’m adding an SSD1306 to an INA 219 - based sensor and I’m hitting a brick wall with compile errors.
I want to display the actual current (in Amps) from the sensor on my display. The INA219 is reporting just fine and the display works with a simple “Hello World” static string test.
I then modified the yaml to print the value for current on the display. Here’s the relevant chunk of code for that:
font:
- file: "fonts/Kanit-Medium.ttf"
# Read Vcc Rail and current
- platform: ina219
address: 0x40
shunt_resistance: 0.1 ohm
current:
power:
bus_voltage:
max_voltage: 32.0V
max_current: 3.2A
# Local current display
display:
- platform: ssd1306_i2c
model: "SSD1306 128x32"
reset_pin: D0
address: 0x3C
lambda: |-
// Print current value
it.print(0, 0, id(OLED_font), "Amps: %.1f", id(Measured_Current).state);
The code validates fine, but I get the following errors when compiling:
src/main.cpp: In lambda function:
src/main.cpp:369:70: error: no matching function for call to 'esphome::display::DisplayBuffer::print(int, int, esphome::display::Font*&, const char [11], float&)'
it.print(0, 0, OLED_font, "Amps: %.1f", Measured_Current->state);
src/main.cpp:369:70: note: candidates are:
In file included from src/esphome.h:3:0,
from src/main.cpp:3:
src/esphome/components/display/display_buffer.h:139:8: note: void esphome::display::DisplayBuffer::print(int, int, esphome::display::Font*, esphome::Color, esphome::display::TextAlign, const char*)
void print(int x, int y, Font *font, Color color, TextAlign align, const char *text);
src/esphome/components/display/display_buffer.h:139:8: note: candidate expects 6 arguments, 5 provided
src/esphome/components/display/display_buffer.h:149:8: note: void esphome::display::DisplayBuffer::print(int, int, esphome::display::Font*, esphome::Color, const char*)
void print(int x, int y, Font *font, Color color, const char *text);
src/esphome/components/display/display_buffer.h:149:8: note: no known conversion for argument 5 from 'float' to 'const char*'
src/esphome/components/display/display_buffer.h:159:8: note: void esphome::display::DisplayBuffer::print(int, int, esphome::display::Font*, esphome::display::TextAlign, const char*)
void print(int x, int y, Font *font, TextAlign align, const char *text);
src/esphome/components/display/display_buffer.h:159:8: note: no known conversion for argument 4 from 'const char [11]' to 'esphome::display::TextAlign'
src/esphome/components/display/display_buffer.h:168:8: note: void esphome::display::DisplayBuffer::print(int, int, esphome::display::Font*, const char*)
void print(int x, int y, Font *font, const char *text);
src/esphome/components/display/display_buffer.h:168:8: note: candidate expects 4 arguments, 5 provided
*** [/data/watchdog_sandbox/.pioenvs/watchdog_sandbox/src/main.cpp.o] Error 1
I feel like I am running around in circles with this one, can anyone suggest some possible debug ideas?
