I’m attempting to compile a yaml inside esphome (2022.6.2) running as an add-on in Home assistant OS (core-2022.6.7). However, whenever i try to compile the yaml, it errors out and terminates the compilation due to “No such file or directory” referring to esphal.h. This is quite confusing to me, as i can navigate to the file’s location in the github repository the yaml is pointing at and can see the file just fine.
I’m quite new to home assistant and esphome, so this might be a bit of an ambitious first project for me, but any help with this would be greatly appreciated. A copy of the yaml, error logs, and a couple links to relevant github files are below. I’d be happy to provide any other necessary files or info.
Hardware: Raspberry Pi4, Nodemcu-32s and tmc2209
YAML:
substitutions:
device_name: val-1000
pulley_diameter_mm: "12.2" # 1 turn about 47 mm
gear_ratio: "1" # not used yet for simplicity
distance_mm: "600" # about 10 turns
acceleration: 600 steps/s^2
velocity: 600 steps/s # 1 turn per second
open_current: 800ma
open_stall_threshold: "20"
close_current: 800ma
close_stall_threshold: "20"
tcool_threshold: "910"
microsteps: "2"
change_direction: "True"
external_components:
source: github://glmnet/esphome@stepper-tmc2209
components: [tmc2209]
esphome:
platform: ESP32
board: nodemcu-32s
platformio_options:
upload_speed: 921600
on_boot:
- tmc2209.setup:
microsteps: 2
tcool_threshold: ${tcool_threshold}
current: 600mA
stall_threshold: 20
wifi:
ssid: SSID
password: PASSWWORD
# Enable logging
logger:
level: INFO
# verbose logger over uart causes motor artifacts as pulses are generated in main loop
# logger:
# level: VERY_VERBOSE
# logs:
# api: DEBUG
# api.service: DEBUG
# scheduler: DEBUG
ota:
uart:
tx_pin: GPIO17
rx_pin: GPIO16
baud_rate: 9600
status_led:
pin: GPIO26
api:
services:
- service: control_stepper
variables:
target: int
speed: int
microsteps: int
tcool_threshold: int
stall_threshold: int
rms_current_amps: float
then:
- tmc2209.setup:
microsteps: !lambda "return microsteps;"
tcool_threshold: !lambda "return tcool_threshold;"
stall_threshold: !lambda "return stall_threshold;"
current: !lambda "return rms_current_amps;"
- logger.log:
format: moving to %d
args: [target]
- stepper.set_speed:
speed: !lambda "return speed;"
- stepper.set_target:
target: !lambda "return target;"
- service: set_stepper_zero
then:
- stepper.report_position:
position: 0
target: 0
binary_sensor:
- platform: gpio
pin:
number: GPIO23
inverted: true
mode: INPUT
on_press:
then:
- cover.open:
- platform: gpio
pin:
number: GPIO34
inverted: true
mode: INPUT
on_press:
then:
- cover.close:
- platform: gpio
pin:
number: GPIO22
inverted: true
- platform: gpio
pin:
number: GPIO0
inverted: true
- platform: gpio
pin:
number: GPIO32
inverted: true
- platform: gpio
pin: GPIO2
on_press:
script.execute: stop_at_current_position
stepper:
- platform: tmc2209
step_pin: GPIO13
dir_pin:
number: GPIO14
inverted: ${change_direction}
sleep_pin:
number: GPIO27
inverted: true
acceleration: ${acceleration}
max_speed: ${velocity}
script:
- id: stop_at_current_position
then:
stepper.set_target:
target: !lambda "return id(my_stepper).current_position;"
globals:
- id: open_position
type: float
initial_value: ${distance_mm} / (${pulley_diameter_mm} * PI) * 200 * ${microsteps}
cover:
open_action:
- tmc2209.setup:
current: ${open_current}
stall_threshold: ${open_stall_threshold}
microsteps: 2
target: !lambda "return id(open_position);"
close_action:
- tmc2209.setup:
current: ${close_current}
stall_threshold: ${close_stall_threshold}
microsteps: 2
# 0 Means closed
target: 0
position_action:
target: !lambda "return id(open_position) * pos;"
stop_action:
- script.execute: stop_at_current_position
interval:
interval: 5s
then:
lambda: |-
static auto operation = COVER_OPERATION_IDLE;
static auto position = id(my_stepper).current_position;
if (operation != id(template_cov).current_operation ||
position != id(my_stepper).current_position)
ESP_LOGD("main", "Stepper Position is: %d/%d", id(my_stepper).current_position, (int)id(open_position));
if (id(my_stepper).current_position > id(my_stepper).target_position)
operation = COVER_OPERATION_CLOSING;
else if (id(my_stepper).current_position < id(my_stepper).target_position)
operation = COVER_OPERATION_OPENING;
else
id(template_cov).current_operation = operation;
id(template_cov).position = position / id(open_position);
id(template_cov).publish_state();
Compile Log:
INFO Reading configuration /config/esphome/val-1000.yaml...
WARNING GPIO0 is a Strapping PIN and should be avoided.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO2 is a Strapping PIN and should be avoided.
INFO Generating C++ source...
INFO Compiling app...
Processing val-1000 (board: nodemcu-32s; framework: arduino; platform: platformio/espressif32 @ 3.5.0)
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Library Manager: Installing teemuatlut/TMCStepper @ 0.7.1
Unpacking [------------------------------------] 0%
Unpacking [------------------------------------] 1%
Unpacking [#-----------------------------------] 3%
Unpacking [##----------------------------------] 5%
Unpacking [##----------------------------------] 7%
Unpacking [###---------------------------------] 9%
Unpacking [####--------------------------------] 11%
Unpacking [####--------------------------------] 13%
Unpacking [#####-------------------------------] 15%
Unpacking [######------------------------------] 16%
Unpacking [######------------------------------] 18%
Unpacking [#######-----------------------------] 20%
Unpacking [########----------------------------] 22%
Unpacking [########----------------------------] 24%
Unpacking [#########---------------------------] 26%
Unpacking [##########--------------------------] 28%
Unpacking [##########--------------------------] 30%
Unpacking [###########-------------------------] 32%
Unpacking [############------------------------] 33%
Unpacking [############------------------------] 35%
Unpacking [#############-----------------------] 37%
Unpacking [##############----------------------] 39%
Unpacking [##############----------------------] 41%
Unpacking [###############---------------------] 43%
Unpacking [################--------------------] 45%
Unpacking [################--------------------] 47%
Unpacking [#################-------------------] 49%
Unpacking [##################------------------] 50%
Unpacking [###################-----------------] 52%
Unpacking [###################-----------------] 54%
Unpacking [####################----------------] 56%
Unpacking [#####################---------------] 58%
Unpacking [#####################---------------] 60%
Unpacking [######################--------------] 62%
Unpacking [#######################-------------] 64%
Unpacking [#######################-------------] 66%
Unpacking [########################------------] 67%
Unpacking [#########################-----------] 69%
Unpacking [#########################-----------] 71%
Unpacking [##########################----------] 73%
Unpacking [###########################---------] 75%
Unpacking [###########################---------] 77%
Unpacking [############################--------] 79%
Unpacking [#############################-------] 81%
Unpacking [#############################-------] 83%
Unpacking [##############################------] 84%
Unpacking [###############################-----] 86%
Unpacking [###############################-----] 88%
Unpacking [################################----] 90%
Unpacking [#################################---] 92%
Unpacking [#################################---] 94%
Unpacking [##################################--] 96%
Unpacking [###################################-] 98%
Unpacking [####################################] 100%
Library Manager: TMCStepper @ 0.7.1 has been installed!
Dependency Graph
|-- <WiFi> 1.0
|-- <ESPmDNS> 1.0
|-- <Update> 1.0
|-- <TMCStepper> 0.7.1
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/api/api_connection.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/api/api_frame_helper.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/api/api_pb2.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/api/api_pb2_service.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/api/api_server.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/api/list_entities.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/api/proto.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/api/subscribe_state.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/api/user_services.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/binary_sensor/automation.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/binary_sensor/binary_sensor.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/binary_sensor/filter.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/cover/cover.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/esp32/core.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/esp32/gpio_arduino.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/esp32/gpio_idf.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/esp32/preferences.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/gpio/binary_sensor/gpio_binary_sensor.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/logger/logger.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/md5/md5.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/mdns/mdns_component.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/mdns/mdns_esp32_arduino.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/mdns/mdns_esp_idf.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/network/util.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/ota/ota_backend_arduino_esp32.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/ota/ota_backend_arduino_esp8266.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/ota/ota_backend_esp_idf.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/ota/ota_component.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/script/script.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/socket/socket.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/status_led/status_led.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/stepper/stepper.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/template/cover/template_cover.cpp.o
Compiling /data/val-1000/.pioenvs/val-1000/src/esphome/components/tmc2209/tmc2209.cpp.o
In file included from src/esphome/components/tmc2209/tmc2209.cpp:1:0:
src/esphome/components/tmc2209/tmc2209.h:4:33: fatal error: esphome/core/esphal.h: No such file or directory
compilation terminated.
*** [/data/val-1000/.pioenvs/val-1000/src/esphome/components/tmc2209/tmc2209.cpp.o] Error 1
========================= [FAILED] Took 34.61 seconds =========================
Thank you again for any advice y’all can provide, I’ve been pulling my hair out at this for a few days now.
