Hi
It seems like this is an issue which occasional recurs, but for me, after upgrading to 2025.7.4 yesterday, I can no longer compile code for my ESP32-C3. I am trying to create a BT proxy, so my yaml is:
esphome:
friendly_name: Bluetooth Proxy WR2
min_version: 2024.12.0
name_add_mac_suffix: true
esp32:
board: esp32-c3-devkitm-1
framework:
type: esp-idf
sdkconfig_options:
CONFIG_BT_BLE_42_FEATURES_SUPPORTED: y
CONFIG_BT_BLE_50_FEATURES_SUPPORTED: n
# Enable logging
logger:
level: VERBOSE
# Enable Home Assistant API
api:
encryption:
key: "blah"
ota:
- platform: esphome
password: "blah blah"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Bt-Proxy-Wr Fallback Hotspot"
password: "blah blah blah"
#captive_portal:
esp32_ble_tracker:
scan_parameters:
# We currently use the defaults to ensure Bluetooth
# can co-exist with WiFi In the future we may be able to
# enable the built-in coexistence logic in ESP-IDF
active: true
bluetooth_proxy:
active: true
button:
- platform: safe_mode
name: Safe Mode Boot
- platform: factory_reset
and I consistently get the error, logged as follows:
INFO ESPHome 2025.7.4
INFO Reading configuration /config/esphome/bt-proxy-wr.yaml…
INFO Generating C++ source…
INFO Compiling app…
Processing bt-proxy-wr (board: esp32-c3-devkitm-1; framework: espidf; platform: https://github.com/pioarduino/platform-espressif32/releases/download/53.03.13/platform-espressif32.zip)
HARDWARE: ESP32C3 160MHz, 320KB RAM, 4MB Flash
- framework-espidf @ 3.50302.0 (5.3.2)
- tool-cmake @ 3.30.2
- tool-esptoolpy @ 4.8.6
- tool-mklittlefs @ 3.2.0
- tool-ninja @ 1.7.1
- tool-riscv32-esp-elf-gdb @ 14.2.0+20240403
- tool-xtensa-esp-elf-gdb @ 14.2.0+20240403
- toolchain-esp32ulp @ 2.35.0-20220830
- toolchain-riscv32-esp @ 13.2.0+20240530
Reading CMake configuration…
– git rev-parse returned ‘fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).’
– Building ESP-IDF components for target esp32c3
– Configuring incomplete, errors occurred!
CMake Error at /data/cache/platformio/packages/framework-espidf/tools/cmake/build.cmake:552 (message):
/root/.platformio/penv/.espidf-5.3.2/bin/python: Error while finding module
specification for ‘idf_component_manager.prepare_components’
(ModuleNotFoundError: No module named ‘idf_component_manager’)
Call Stack (most recent call first):
/data/cache/platformio/packages/framework-espidf/tools/cmake/project.cmake:710 (idf_build_process)
CMakeLists.txt:3 (project)
========================== [FAILED] Took 3.77 seconds ==========================
Any ideas on how to fix it? I have tried doing a Clean Build Files (no change), and also tried reverting to an earlier version (it never finished downloading).
Alex
