hello! I’m trying to add a battery sensor to a device using a seeed xiao ESP32c6. I have a voltage divider attached to pin D1(GPIO1). I am trying to compile on a mac running the espHome web interface locally. I have espHome version 2024.12.4. A reduced version of my yaml that gets the same error looks like this:
esphome:
friendly_name: balcony_seeed
esp32:
board: esp32-c6-devkitm-1
variant: esp32c6
framework:
type: esp-idf
version: "5.3.1"
platform_version: 6.9.0
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxxx"
ota:
- platform: esphome
password: "xxxxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Seed-Balcony Fallback Hotspot"
password: "xxxxxxx"
- platform: adc
pin: GPIO1
update_interval: 60s
the error message is as follows:
INFO ESPHome 2024.12.4
INFO Reading configuration /Users/obucklin/Documents/repos/HomeAssistant/espHome/adc-test.yaml...
WARNING The selected ESP-IDF framework version is not the recommended one. If there are connectivity or build issues please remove the manual version.
WARNING 'seeed_balcony_controller': Using the '_' (underscore) character in the hostname is discouraged as it can cause problems with some DHCP and local name services. For more information, see https://esphome.io/guides/faq.html#why-shouldn-t-i-use-underscores-in-my-device-name
INFO Generating C++ source...
INFO Updating https://github.com/espressif/[email protected]
INFO Compiling app...
Processing seeed_balcony_controller (board: esp32-c6-devkitm-1; framework: espidf; platform: platformio/[email protected])
HARDWARE: ESP32C6 160MHz, 320KB RAM, 4MB Flash
- framework-espidf @ 3.50301.0 (5.3.1)
- tool-cmake @ 3.16.4
- tool-ninja @ 1.9.0
- tool-riscv32-esp-elf-gdb @ 12.1.0+20221002
- tool-xtensa-esp-elf-gdb @ 12.1.0+20221002
- toolchain-esp32ulp @ 2.35.0-20220830
- toolchain-riscv32-esp @ 13.2.0+20240530
Reading CMake configuration...
Dependency Graph
|-- noise-c @ 0.1.6
Compiling .pioenvs/seeed_balcony_controller/src/esphome/components/adc/adc_sensor_common.cpp.o
Compiling .pioenvs/seeed_balcony_controller/src/esphome/components/adc/adc_sensor_esp32.cpp.o
Compiling .pioenvs/seeed_balcony_controller/src/esphome/components/api/proto.cpp.o
Compiling .pioenvs/seeed_balcony_controller/src/esphome/components/api/subscribe_state.cpp.o
Compiling .pioenvs/seeed_balcony_controller/src/esphome/components/api/user_services.cpp.o
Compiling .pioenvs/seeed_balcony_controller/src/esphome/components/esp32/core.cpp.o
Compiling .pioenvs/seeed_balcony_controller/src/esphome/components/esp32/gpio.cpp.o
Compiling .pioenvs/seeed_balcony_controller/src/esphome/components/esp32/preferences.cpp.o
In file included from src/esphome/components/adc/adc_sensor.h:9,
from src/esphome/components/adc/adc_sensor_common.cpp:1:
/Users/obucklin/.platformio/packages/framework-espidf/components/esp_adc/deprecated/include/esp_adc_cal.h:17:2: warning: #warning "legacy adc calibration driver is deprecated, please migrate to use esp_adc/adc_cali.h and esp_adc/adc_cali_scheme.h" [-Wcpp]
17 | #warning "legacy adc calibration driver is deprecated, please migrate to use esp_adc/adc_cali.h and esp_adc/adc_cali_scheme.h"
from src/esphome/components/adc/adc_sensor_esp32.cpp:3:
In file included from src/esphome/components/adc/adc_sensor.h:10:
/Users/obucklin/.platformio/packages/framework-espidf/components/driver/deprecated/driver/adc.h:19:2: warning: #warning "legacy adc driver is deprecated, please migrate to use esp_adc/adc_oneshot.h and esp_adc/adc_continuous.h for oneshot mode and continuous mode drivers respectively" [-Wcpp]
19 | #warning "legacy adc driver is deprecated, please migrate to use esp_adc/adc_oneshot.h and esp_adc/adc_continuous.h for oneshot mode and continuous mode drivers respectively"
Compiling .pioenvs/seeed_balcony_controller/src/esphome/components/esphome/ota/ota_esphome.cpp.o
src/esphome/components/adc/adc_sensor.h:40:21: error: 'adc2_channel_t' has not been declared
40 | void set_channel2(adc2_channel_t channel) {
src/esphome/components/adc/adc_sensor.h:79:3: error: 'adc2_channel_t' does not name a type; did you mean 'adc_channel_t'?
79 | adc2_channel_t channel2_{ADC2_CHANNEL_MAX};
| adc_channel_t
src/esphome/components/adc/adc_sensor.h:82:3: error: 'esp_adc_cal_characteristics_t' does not name a type
82 | esp_adc_cal_characteristics_t cal_characteristics_[SOC_ADC_ATTEN_NUM] = {};
src/esphome/components/adc/adc_sensor.h: In member function 'void esphome::adc::ADCSensor::set_channel1(adc1_channel_t)':
src/esphome/components/adc/adc_sensor.h:38:11: error: 'class esphome::adc::ADCSensor' has no member named 'channel2_'; did you mean 'channel1_'?
38 | this->channel2_ = ADC2_CHANNEL_MAX;
| channel1_
| adc_channel_t
src/esphome/components/adc/adc_sensor.h:38:23: error: 'ADC2_CHANNEL_MAX' was not declared in this scope; did you mean 'ADC1_CHANNEL_MAX'?
| ADC1_CHANNEL_MAX
src/esphome/components/adc/adc_sensor.h: In member function 'void esphome::adc::ADCSensor::set_channel2(int)':
src/esphome/components/adc/adc_sensor.h:41:11: error: 'class esphome::adc::ADCSensor' has no member named 'channel2_'; did you mean 'channel1_'?
41 | this->channel2_ = channel;
| channel1_
src/esphome/components/adc/adc_sensor_esp32.cpp: In member function 'virtual void esphome::adc::ADCSensor::setup()':
src/esphome/components/adc/adc_sensor_esp32.cpp:32:20: error: 'class esphome::adc::ADCSensor' has no member named 'channel2_'; did you mean 'channel1_'?
32 | } else if (this->channel2_ != ADC2_CHANNEL_MAX) {
| channel1_
| channel1_
src/esphome/components/adc/adc_sensor_esp32.cpp:32:33: error: 'ADC2_CHANNEL_MAX' was not declared in this scope; did you mean 'ADC1_CHANNEL_MAX'?
| ADC1_CHANNEL_MAX
src/esphome/components/adc/adc_sensor_esp32.cpp:34:39: error: 'class esphome::adc::ADCSensor' has no member named 'channel2_'; did you mean 'channel1_'?
34 | adc2_config_channel_atten(this->channel2_, this->attenuation_);
| channel1_
src/esphome/components/adc/adc_sensor_esp32.cpp:34:7: error: 'adc2_config_channel_atten' was not declared in this scope; did you mean 'adc1_config_channel_atten'?
src/esphome/components/adc/adc_sensor_esp32.cpp:42:54: error: 'class esphome::adc::ADCSensor' has no member named 'cal_characteristics_'
42 | &this->cal_characteristics_[i]);
| ADC1_CHANNEL_MAX
| channel1_
src/esphome/components/adc/adc_sensor_esp32.cpp:40:22: error: 'esp_adc_cal_characterize' was not declared in this scope
40 | auto cal_value = esp_adc_cal_characterize(adc_unit, (adc_atten_t) i, ADC_WIDTH_MAX_SOC_BITS,
src/esphome/components/adc/adc_sensor_esp32.cpp:44:12: error: 'ESP_ADC_CAL_VAL_EFUSE_VREF' was not declared in this scope
44 | case ESP_ADC_CAL_VAL_EFUSE_VREF:
src/esphome/components/adc/adc_sensor_esp32.cpp:47:12: error: 'ESP_ADC_CAL_VAL_EFUSE_TP' was not declared in this scope
47 | case ESP_ADC_CAL_VAL_EFUSE_TP:
src/esphome/components/adc/adc_sensor_esp32.cpp:50:12: error: 'ESP_ADC_CAL_VAL_DEFAULT_VREF' was not declared in this scope
50 | case ESP_ADC_CAL_VAL_DEFAULT_VREF:
src/esphome/components/adc/adc_sensor_esp32.cpp: In member function 'virtual float esphome::adc::ADCSensor::sample()':
src/esphome/components/adc/adc_sensor_esp32.cpp:91:24: error: 'class esphome::adc::ADCSensor' has no member named 'channel2_'; did you mean 'channel1_'?
91 | } else if (this->channel2_ != ADC2_CHANNEL_MAX) {
| channel1_
src/esphome/components/adc/adc_sensor_esp32.cpp:91:37: error: 'ADC2_CHANNEL_MAX' was not declared in this scope; did you mean 'ADC1_CHANNEL_MAX'?
| ADC1_CHANNEL_MAX
src/esphome/components/adc/adc_sensor_esp32.cpp:92:28: error: 'class esphome::adc::ADCSensor' has no member named 'channel2_'; did you mean 'channel1_'?
92 | adc2_get_raw(this->channel2_, ADC_WIDTH_MAX_SOC_BITS, &raw);
| channel1_
src/esphome/components/adc/adc_sensor_esp32.cpp:92:9: error: 'adc2_get_raw' was not declared in this scope; did you mean 'adc1_get_raw'?
| adc1_get_raw
src/esphome/components/adc/adc_sensor_esp32.cpp:103:58: error: 'class esphome::adc::ADCSensor' has no member named 'cal_characteristics_'
103 | uint32_t mv = esp_adc_cal_raw_to_voltage(sum, &this->cal_characteristics_[(int32_t) this->attenuation_]);
src/esphome/components/adc/adc_sensor_esp32.cpp:103:19: error: 'esp_adc_cal_raw_to_voltage' was not declared in this scope
src/esphome/components/adc/adc_sensor_esp32.cpp:124:20: error: 'class esphome::adc::ADCSensor' has no member named 'channel2_'; did you mean 'channel1_'?
124 | } else if (this->channel2_ != ADC2_CHANNEL_MAX) {
| channel1_
src/esphome/components/adc/adc_sensor_esp32.cpp:124:33: error: 'ADC2_CHANNEL_MAX' was not declared in this scope; did you mean 'ADC1_CHANNEL_MAX'?
| ADC1_CHANNEL_MAX
src/esphome/components/adc/adc_sensor_esp32.cpp:125:37: error: 'class esphome::adc::ADCSensor' has no member named 'channel2_'; did you mean 'channel1_'?
125 | adc2_config_channel_atten(this->channel2_, ADC_ATTEN_DB_12_COMPAT);
| channel1_
src/esphome/components/adc/adc_sensor_esp32.cpp:125:5: error: 'adc2_config_channel_atten' was not declared in this scope; did you mean 'adc1_config_channel_atten'?
src/esphome/components/adc/adc_sensor_esp32.cpp:126:24: error: 'class esphome::adc::ADCSensor' has no member named 'channel2_'; did you mean 'channel1_'?
126 | adc2_get_raw(this->channel2_, ADC_WIDTH_MAX_SOC_BITS, &raw12);
| channel1_
Compiling .pioenvs/seeed_balcony_controller/src/esphome/components/logger/logger.cpp.o
src/esphome/components/adc/adc_sensor_esp32.cpp:126:5: error: 'adc2_get_raw' was not declared in this scope; did you mean 'adc1_get_raw'?
| adc1_get_raw
src/esphome/components/adc/adc_sensor_esp32.cpp:128:39: error: 'class esphome::adc::ADCSensor' has no member named 'channel2_'; did you mean 'channel1_'?
128 | adc2_config_channel_atten(this->channel2_, ADC_ATTEN_DB_6);
| channel1_
src/esphome/components/adc/adc_sensor_esp32.cpp:129:26: error: 'class esphome::adc::ADCSensor' has no member named 'channel2_'; did you mean 'channel1_'?
129 | adc2_get_raw(this->channel2_, ADC_WIDTH_MAX_SOC_BITS, &raw6);
| channel1_
src/esphome/components/adc/adc_sensor_esp32.cpp:131:41: error: 'class esphome::adc::ADCSensor' has no member named 'channel2_'; did you mean 'channel1_'?
131 | adc2_config_channel_atten(this->channel2_, ADC_ATTEN_DB_2_5);
| channel1_
src/esphome/components/adc/adc_sensor_esp32.cpp:132:28: error: 'class esphome::adc::ADCSensor' has no member named 'channel2_'; did you mean 'channel1_'?
132 | adc2_get_raw(this->channel2_, ADC_WIDTH_MAX_SOC_BITS, &raw2);
| channel1_
src/esphome/components/adc/adc_sensor_esp32.cpp:134:43: error: 'class esphome::adc::ADCSensor' has no member named 'channel2_'; did you mean 'channel1_'?
134 | adc2_config_channel_atten(this->channel2_, ADC_ATTEN_DB_0);
| channel1_
src/esphome/components/adc/adc_sensor_esp32.cpp:135:30: error: 'class esphome::adc::ADCSensor' has no member named 'channel2_'; did you mean 'channel1_'?
135 | adc2_get_raw(this->channel2_, ADC_WIDTH_MAX_SOC_BITS, &raw0);
| channel1_
src/esphome/components/adc/adc_sensor_esp32.cpp:145:60: error: 'class esphome::adc::ADCSensor' has no member named 'cal_characteristics_'
145 | uint32_t mv12 = esp_adc_cal_raw_to_voltage(raw12, &this->cal_characteristics_[(int32_t) ADC_ATTEN_DB_12_COMPAT]);
*** [.pioenvs/seeed_balcony_controller/src/esphome/components/adc/adc_sensor_common.cpp.o] Error 1
src/esphome/components/adc/adc_sensor_esp32.cpp:145:19: error: 'esp_adc_cal_raw_to_voltage' was not declared in this scope
src/esphome/components/adc/adc_sensor_esp32.cpp:146:58: error: 'class esphome::adc::ADCSensor' has no member named 'cal_characteristics_'
146 | uint32_t mv6 = esp_adc_cal_raw_to_voltage(raw6, &this->cal_characteristics_[(int32_t) ADC_ATTEN_DB_6]);
src/esphome/components/adc/adc_sensor_esp32.cpp:147:58: error: 'class esphome::adc::ADCSensor' has no member named 'cal_characteristics_'
147 | uint32_t mv2 = esp_adc_cal_raw_to_voltage(raw2, &this->cal_characteristics_[(int32_t) ADC_ATTEN_DB_2_5]);
src/esphome/components/adc/adc_sensor_esp32.cpp:148:58: error: 'class esphome::adc::ADCSensor' has no member named 'cal_characteristics_'
148 | uint32_t mv0 = esp_adc_cal_raw_to_voltage(raw0, &this->cal_characteristics_[(int32_t) ADC_ATTEN_DB_0]);
*** [.pioenvs/seeed_balcony_controller/src/esphome/components/adc/adc_sensor_esp32.cpp.o] Error 1
========================== [FAILED] Took 3.27 seconds ==========================
I know the c6 is not yet fully supported or was recently added, so I expect this may be part of the problem.
I tried reinstalling esphome with homebrew, I tried a few different GPIO pins, but no luck.
Anyways, if anyone could lend me a hand I would much appreciate it!
