Compiling Bruh MultiSensors Without PIR Motion Sensor and RGB LED
Learned of HA last month and bought the components to put together 5 Bruh multisensors omitting the PIR Motion Sensor and RGB LED. I’m psyched the parts arrived today. The pinouts and setting up HA on an Ubuntu VM has been a breeze.
I’ve successfully compiled Bruh’s stock code that includes the PIR Motion Sensor and RGB LED that I do not have. Now my goal is to comment out the PIR and LED code from the ESP8266 firmware and HA yaml config. I’m not a coder and don’t want to flash a dirty firmware to the ESP8266 boards and understand YAML can be a harsh mistress regarding spaces etc. . I’ve attempted to comment out of the firrmware what I guestimate needs to be commented out and am convinced I’ve butchered it.
Bruh’s stock ESP8266 firmware code.
https://raw.githubusercontent.com/bruhautomation/ESP-MQTT-JSON-Multisensor/master/bruh_mqtt_multisensor_github/bruh_mqtt_multisensor_github.ino
I’d immensely appreciate if someone arduino firmware and yaml savvy could post clean code or markup on all the things that I’ve goofed. The forum is preventing me from posting the commented code because of hyperlinks so I’ll try it in a following post.
#include <ESP8266WiFi.h>
#include <DHT.h>
#include <PubSubClient.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <ArduinoJson.h>
/************ WIFI and MQTT INFORMATION (CHANGE THESE FOR YOUR SETUP) ******************/
#define wifi_ssid “YourSSID” //type your WIFI information inside the quotes
#define wifi_password “YourWIFIpassword”
#define mqtt_server “your.mqtt.server.ip”
#define mqtt_user “yourMQTTusername”
#define mqtt_password “yourMQTTpassword”
#define mqtt_port 1883
/************* MQTT TOPICS (change these topics as you wish) **************************/
#define sensornode1_state_topic “bruh/sensornode1”
#define sensornode1_set_topic “bruh/sensornode1/set”
const char* on_cmd = “ON”;
const char* off_cmd = “OFF”;
/**************************** FOR OTA **************************************************/
#define SENSORNAME “sensornode1”
#define OTApassword “YouPassword” // change this to whatever password you want to use when you upload OTA
int OTAport = 8266;
/**************************** PIN DEFINITIONS ********************************************/
/const int redPin = D1;/
/const int greenPin = D2;/
/const int bluePin = D3;/
/#define PIRPIN D5/
#define DHTPIN D7
#define DHTTYPE DHT22
#define LDRPIN A0
/**************************** SENSOR DEFINITIONS *******************************************/
float ldrValue;
int LDR;
float calcLDR;
float diffLDR = 25;
float diffTEMP = 0.2;
float tempValue;
float diffHUM = 1;
float humValue;
/int pirValue;/
/int pirStatus;/
/String motionStatus;/
char message_buff[100];
int calibrationTime = 0;
const int BUFFER_SIZE = 300;
#define MQTT_MAX_PACKET_SIZE 512
/******************************** GLOBALS for fade/flash *******************************/
/*byte red = 255;
byte green = 255;
byte blue = 255;
byte brightness = 255;
byte realRed = 0;
byte realGreen = 0;
byte realBlue = 0;
bool stateOn = false;
bool startFade = false;
unsigned long lastLoop = 0;
int transitionTime = 0;
bool inFade = false;
int loopCount = 0;
int stepR, stepG, stepB;
int redVal, grnVal, bluVal;
bool flash = false;
bool startFlash = false;
int flashLength = 0;
unsigned long flashStartTime = 0;
byte flashRed = red;
byte flashGreen = green;
byte flashBlue = blue;
byte flashBrightness = brightness;*/
WiFiClient espClient;
PubSubClient client(espClient);
DHT dht(DHTPIN, DHTTYPE);
/********************************** START SETUP*****************************************/
void setup() {
Serial.begin(115200);
/pinMode(PIRPIN, INPUT);/
pinMode(DHTPIN, INPUT);
pinMode(LDRPIN, INPUT);
delay(10);
ArduinoOTA.setPort(OTAport);
ArduinoOTA.setHostname(SENSORNAME);
ArduinoOTA.setPassword((const char *)OTApassword);
Serial.print(“calibrating sensor “);
for (int i = 0; i < calibrationTime; i++) {
Serial.print(”.”);
delay(1000);
Serial.println("Starting Node named " + String(SENSORNAME));
setup_wifi();
client.setServer(mqtt_server, mqtt_port);
client.setCallback(callback);
ArduinoOTA.onStart( {
Serial.println(“Starting”);
ArduinoOTA.onEnd( {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf(“Progress: %u%%\r”, (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println(“Auth Failed”);
else if (error == OTA_BEGIN_ERROR) Serial.println(“Begin Failed”);
else if (error == OTA_CONNECT_ERROR) Serial.println(“Connect Failed”);
else if (error == OTA_RECEIVE_ERROR) Serial.println(“Receive Failed”);
else if (error == OTA_END_ERROR) Serial.println(“End Failed”);
ArduinoOTA.begin();
Serial.println(“Ready”);
Serial.print("IPess: ");
Serial.println(WiFi.localIP());
reconnect();
/********************************** START SETUP WIFI*****************************************/
void setup_wifi() {
delay(10);
Serial.println();
Serial.print("Connecting to ");
Serial.println(wifi_ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(wifi_ssid, wifi_password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println(“WiFi connected”);
Serial.println("IP address: ");
/********************************** START CALLBACK*****************************************/
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print(“Message arrived [”);
Serial.print(topic);
Serial.print("] ");
char message[length + 1];
for (int i = 0; i < length; i++) {
message[i] = (char)payload[i];
message[length] = ‘\0’;
Serial.println(message);
if (!processJson(message)) {
return;
/*if (stateOn) {
// Update lights
realRed = map(red, 0, 255, 0, brightness);
realGreen = map(green, 0, 255, 0, brightness);
realBlue = map(blue, 0, 255, 0, brightness);
else {
realRed = 0;
realGreen = 0;
realBlue = 0;
startFade = true;
inFade = false; // Kill the current fade*/
sendState();
/********************************** START PROCESS JSON*****************************************/
bool processJson(char* message) {
StaticJsonBuffer<BUFFER_SIZE> jsonBuffer;
JsonObject& root = jsonBuffer.parseObject(message);
if (!root.success()) {
Serial.println(“parseObject() failed”);
return false;
if (root.containsKey(“state”)) {
if (strcmp(root[“state”], on_cmd) == 0) {
stateOn = true;
else if (strcmp(root[“state”], off_cmd) == 0) {
stateOn = false;
/*// If “flash” is included, treat RGB and brightness differently
if (root.containsKey(“flash”)) {
flashLength = (int)root[“flash”] * 1000;
if (root.containsKey("brightness")) {
  flashBrightness = root["brightness"];
else {
if (root.containsKey("color")) {
  flashRed = root["color"]["r"];
  flashGreen = root["color"]["g"];
  flashBlue = root["color"]["b"];
else {
  flashRed = red;
  flashGreen = green;
  flashBlue = blue;
flashRed = map(flashRed, 0, 255, 0, flashBrightness);
flashGreen = map(flashGreen, 0, 255, 0, flashBrightness);
flashBlue = map(flashBlue, 0, 255, 0, flashBrightness);
flash = true;
startFlash = true;
else { // Not flashing
flash = false;
  red = root["color"]["r"];
  green = root["color"]["g"];
  blue = root["color"]["b"];
  brightness = root["brightness"];
if (root.containsKey("transition")) {
  transitionTime = root["transition"];
else {
  transitionTime = 0;*/
return true;
/********************************** START SEND STATE*****************************************/
void sendState() {
JsonObject& root = jsonBuffer.createObject();
*root[“state”] = (stateOn) ? on_cmd : off_cmd;
JsonObject& color = root.createNestedObject(“color”);
color[“r”] = red;
color[“g”] = green;
color[“b”] = blue;*/
root[“brightness”] = brightness;
root[“humidity”] = (String)humValue;
*root[“motion”] = (String)motionStatus;*
root[“ldr”] = (String)LDR;
root[“temperature”] = (String)tempValue;
root[“heatIndex”] = (String)calculateHeatIndex(humValue, tempValue);
char buffer[root.measureLength() + 1];
root.printTo(buffer, sizeof(buffer));
Serial.println(buffer);
client.publish(sensornode1_state_topic, buffer, true);
  • Calculate Heat Index value AKA “Real Feel”
  • NOAA heat index calculations taken from
  • http://www.wpc.ncep.noaa.gov/html/heatindex_equation.shtml
    float calculateHeatIndex(float humidity, float temp) {
    float heatIndex= 0;
    if (temp >= 80) {
    heatIndex = -42.379 + 2.04901523
    temp + 10.14333127humidity;
    heatIndex = heatIndex - .22475541
    temphumidity - .00683783temptemp;
    heatIndex = heatIndex - .05481717
    humidityhumidity + .00122874temptemphumidity;
    heatIndex = heatIndex + .00085282temphumidityhumidity - .00000199temptemphumidity*humidity;
    } else {
    heatIndex = 0.5 * (temp + 61.0 + ((temp - 68.0)*1.2) + (humidity * 0.094));
if (humidity < 13 && 80 <= temp <= 112) {
float adjustment = ((13-humidity)/4) * sqrt((17-abs(temp-95.))/17);
heatIndex = heatIndex - adjustment;
return heatIndex;
/********************************** START SET COLOR *****************************************/
/*void setColor(int inR, int inG, int inB) {
analogWrite(redPin, inR);
analogWrite(greenPin, inG);
analogWrite(bluePin, inB);
Serial.println(“Setting LEDs:”);
Serial.print("r: “);
Serial.print(inR);
Serial.print(”, g: “);
Serial.print(inG);
Serial.print(”, b: ");
Serial.println(inB);
/********************************** START RECONNECT*****************************************/
void reconnect() {
// Loop until we’re reconnected
while (!client.connected()) {
Serial.print(“Attempting MQTT connection…”);
// Attempt to connect
if (client.connect(SENSORNAME, mqtt_user, mqtt_password)) {
Serial.println(“connected”);
client.subscribe(sensornode1_set_topic);
/setColor(0, 0, 0);/
sendState();
} else {
Serial.print(“failed, rc=”);
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
/********************************** START CHECK SENSOR **********************************/
bool checkBoundSensor(float newValue, float prevValue, float maxDiff) {
return newValue < prevValue - maxDiff || newValue > prevValue + maxDiff;
/********************************** START MAIN LOOP***************************************/
void loop() {
ArduinoOTA.handle();
if (!client.connected()) {
// reconnect();
software_Reset();
client.loop();
if (!inFade) {
float newTempValue = dht.readTemperature(true); //to use celsius remove the true text inside the parentheses
float newHumValue = dht.readHumidity();
//PIR CODE
pirValue = digitalRead(PIRPIN); //read state of the
if (pirValue == LOW && pirStatus != 1) {
  motionStatus = "standby";
  sendState();
  pirStatus = 1;
else if (pirValue == HIGH && pirStatus != 2) {
  motionStatus = "motion detected";
  sendState();
  pirStatus = 2;
delay(100);
if (checkBoundSensor(newTempValue, tempValue, diffTEMP)) {
  tempValue = newTempValue;
  sendState();
if (checkBoundSensor(newHumValue, humValue, diffHUM)) {
  humValue = newHumValue;
  sendState();
int newLDR = analogRead(LDRPIN);
if (checkBoundSensor(newLDR, LDR, diffLDR)) {
  LDR = newLDR;
  sendState();
if (flash) {
if (startFlash) {
startFlash = false;
flashStartTime = millis();
if ((millis() - flashStartTime) <= flashLength) {
  if ((millis() - flashStartTime) % 1000 <= 500) {
    setColor(flashRed, flashGreen, flashBlue);
  else {
    setColor(0, 0, 0);
    // If you'd prefer the flashing to happen "on top of"
    // the current color, uncomment the next line.
    // setColor(realRed, realGreen, realBlue);
else {
  flash = false;
if (startFade) {
// If we don’t want to fade, skip it.
if (transitionTime == 0) {
  redVal = realRed;
  grnVal = realGreen;
  bluVal = realBlue;
  startFade = false;
else {
  loopCount = 0;
  stepR = calculateStep(redVal, realRed);
  stepG = calculateStep(grnVal, realGreen);
  stepB = calculateStep(bluVal, realBlue);
  inFade = true;
if (inFade) {
startFade = false;
unsigned long now = millis();
if (now - lastLoop > transitionTime) {
if (loopCount <= 1020) {
lastLoop = now;
    redVal = calculateVal(stepR, redVal, loopCount);
    grnVal = calculateVal(stepG, grnVal, loopCount);
    bluVal = calculateVal(stepB, bluVal, loopCount);
    setColor(redVal, grnVal, bluVal); // Write current values to LED pins
    Serial.print("Loop count: ");
    Serial.println(loopCount);
    loopCount++;
  else {
    inFade = false;
/**************************** START TRANSITION FADER ****************************************/
// From https://www.arduino.cc/en/Tutorial/ColorCrossfader
BELOW THIS LINE IS THE MATH – YOU SHOULDN’T NEED TO CHANGE THIS FOR THE BASICS
The program works like this:
Imagine a crossfade that moves the red LED from 0-10,
the green from 0-5, and the blue from 10 to 7, in
ten steps.
We’d want to count the 10 steps and increase or
decrease color values in evenly stepped increments.
Imagine a + indicates raising a value by 1, and a -
equals lowering it. Our 10 step fade would look like:
1 2 3 4 5 6 7 8 9 10
R + + + + + + + + + +
G + + + + +
B - - -
The red rises from 0 to 10 in ten steps, the green from
0-5 in 5 steps, and the blue falls from 10 to 7 in three steps.
In the real program, the color percentages are converted to
0-255 values, and there are 1020 steps (255*4).
To figure out how big a step there should be between one up- or
down-tick of one of the LED values, we call calculateStep(),
which calculates the absolute gap between the start and end values,
and then divides that gap by 1020 to determine the size of the step
between adjustments in the value.
int calculateStep(int prevValue, int endValue) {
int step = endValue - prevValue; // What’s the overall gap?
if (step) { // If its non-zero,
step = 1020 / step; // divide by 1020
return step;
/* The next function is calculateVal. When the loop value, i,
reaches the step size appropriate for one of the
colors, it increases or decreases the value of that color by 1.
(R, G, and B are each calculated separately.)
int calculateVal(int step, int val, int i) {
if ((step) && i % step == 0) { // If step is non-zero and its time to change a value,
if (step > 0) { // increment the value if step is positive…
val += 1;
else if (step < 0) { // …or decrement it if step is negative
val -= 1;
// Defensive driving: make sure val stays in the range 0-255
if (val > 255) {
val = 255;
else if (val < 0) {
val = 0;
return val;
/*reset/
void software_Reset() // Restarts program from beginning but does not reset the peripherals and registers
Serial.print(“resetting”);
ESP.reset();
I’m no expert, but you have posted the code that gets flashed to the esp8266 microcontroller, not a yaml file.
Never the less, I think you should just leave it in there unless you need to conserve memory space for other code or sensors you intend to replace the ones you will omit.
Point is, when I physically remove one of those sensors from my Bruh multisensor set up, I just then leave out all reference to it in the configuration.yaml on HA.
This might be silly to show an example of something not there, but here is one of my multisensor that I have removed the DHT22 temperature and Humidity sensor:
I hope this helps.
  • platform: mqtt
    state_topic: “bruh/sensornode1”
    icon: mdi:sunglasses
    ##This sensor is not calibrated to actual LUX. Rather, this a map of the input voltage ranging from 0 - 1023.
    unit_of_measurement: “LUX”
    value_template: ‘{{ value_json.ldr }}’
  • platform: mqtt
    icon: mdi:walk
    value_template: ‘{{ value_json.motion }}’
@bobbyhotpants You are correct. I stated that incorrectly in the initial post. I quick fixed that.
Excellent suggestion of leaving the FW and just omitting the PIR from HA to get me going for now. Hopefully the FW won’t misbehave for lack of the PIR and LED connected to the esp8266.
I am psyched to add additional sensors to the esp8266 in the future. For that reason I’d bought 5 esp8266. I’ll give your suggestion a shot this afternoon and post back.
Hopefully someone else can help commenting out the PIR and LED stuff from the firmware which would be valuable to folks not needing the PIR or LED bruh incidentally included in his setup.
I have taken Bruh Multisensor code and removed the LEDs and changed the light sensor and temp/humidity semsor. I left the PIR in as I use that. I have a copy up on my github if you want to take a look at it and see it with all the LED code removed. It should help you get started in the right direction.
@bobbyhotpants It does work with all the extra stuff left in the firmware. I was able to get the sensors working with HA after removing the group component of Bruh’s code. There were half dozen other things that have changed since Bruh posted his youtube guide but that was the most important step for HA anyways.
@one-love Fantastic. Greatly appreciated! I’ll explore your slimmer firmware tomorrow. I’m optimistic commenting out the PIR will be easy. Have a great night all.
Hii i am new into home assistant, i happened to have an esp32 module as against BRUH esp8266 and after editing the code to my board and available components, when i run the code i am told analogWrite wasn’t declared in the scope. can someone help me checkout the code for my mistake
[b]#include <WiFi.h>
#include <DHT.h>
#include <ESPmDNS.h>
/************ TEMP SETTINGS (CHANGE THIS FOR YOUR SETUP) *******************************/
#define IsFahrenheit false //to use celsius change to false
#define wifi_ssid “#####” //type your WIFI information inside the quotes
#define wifi_password “####”
#define mqtt_server “192.168.0.129”
#define mqtt_user “####”
#define mqtt_password “####”
#define light_state_topic “bruh/sensornode1”
#define light_set_topic “bruh/sensornode1/set”
#define OTApassword “#####” // change this to whatever password you want to use when you upload OTA
int OTAport = 8266;
const int redPin = 15;
const int greenPin = 2;
const int bluePin = 4;
#define PIRPIN 5
#define DHTPIN 18
#define DHTTYPE DHT11
#define LDRPIN 13
float ldrValue;
int LDR;
float calcLDR;
float diffLDR = 25;
float tempValue;
float diffHUM = 1;
float humValue;
int pirValue;
int pirStatus;
byte red = 255;
byte green = 255;
byte blue = 255;
byte realRed = 0;
byte realGreen = 0;
byte realBlue = 0;
int loopCount = 0;
bool flash = false;
void setup() {
delay(10);
Serial.print(”.”);
delay(1000);
setup_wifi();
ArduinoOTA.onEnd( {
ArduinoOTA.begin();
reconnect();
void setup_wifi() {
delay(10);
Serial.println();
delay(500);
Serial.print(".");
Serial.println("");
Serial.print("] ");
return;
if (stateOn) {
// Update lights
else {
realRed = 0;
realGreen = 0;
realBlue = 0;
startFade = true;
sendState();
StaticJsonBuffer<BUFFER_SIZE> JsonBuffer;
JsonObject& root = JsonBuffer.parseObject(message);
return false;
stateOn = true;
stateOn = false;
else {
else {
  flashRed = red;
  flashGreen = green;
  flashBlue = blue;
flash = true;
startFlash = true;
flash = false;
else {
  transitionTime = 0;
return true;
void sendState() {
JsonObject& root = JsonBuffer.createObject();
color[“r”] = red;
color[“g”] = green;
color[“b”] = blue;
root[“heatIndex”] = (String)dht.computeHeatIndex(tempValue, humValue, IsFahrenheit);
client.publish(light_state_topic, buffer, true);
analogWrite(redPin, R);
analogWrite(greenPin, G);
analogWrite(bluePin, B);
Serial.print(R);
Serial.print(G);
Serial.println(B);
void reconnect() {
client.subscribe(light_set_topic);
setColor(0, 0, 0);
sendState();
} else {
delay(5000);
void loop() {
// reconnect();
software_Reset();
client.loop();
if (!inFade) {
float newTempValue = dht.readTemperature(IsFahrenheit);
//PIR CODE
  sendState();
  pirStatus = 1;
  sendState();
  pirStatus = 2;
delay(100);
  sendState();
  sendState();
  LDR = newLDR;
  sendState();
if (flash) {
if (startFlash) {
startFlash = false;
  else {
    setColor(0, 0, 0);
else {
  flash = false;
if (startFade) {
  redVal = realRed;
  grnVal = realGreen;
  bluVal = realBlue;
  startFade = false;
else {
  loopCount = 0;
  inFade = true;
if (inFade) {
startFade = false;
lastLoop = now;
    loopCount++;
  else {
    inFade = false;
[/b]
