Good night,
I will appreciate a lot if anyone can help me with the following problem that i have, I have problems trying to install my program to a wemos d1 mini in esphome, every time that I try to install it I get the following message, this problem is while esphome is compiling.
Error: Could not find ‘eagle.flash.4m.ld’ LD script in LDPATH ‘/data/screen01/.pioenvs/screen01 /data/screen01/.pioenvs/screen01/ld /data/cache/platformio/packages/framework-arduinoespressif8266/tools/sdk/lib /data/cache/platformio/packages/framework-arduinoespressif8266/tools/sdk/ld /data/cache/platformio/packages/framework-arduinoespressif8266/tools/sdk/lib/NONOSDK22x_190703’
========================== [FAILED] Took 7.96 seconds ==========================
Thank you in advance
