Complete beginner, cannot detect Google Home
Hi, I set up Home Assistant on Windows a week or two ago and it’s been working without any issues.
I’ve not changed anything, however, yesterday it’s stopped broadcasting/casting to my Google Home. After some investigating (I don’t know what I’m doing really!) I’ve realised it’s no longer finding the speaker.
It has a static IP address, as does the PC, but it’s not finding it.
It detects my Harmony Hub as well as a few other things (Plex server etc).
I’ve restarted the router, pc and Google Home multiple times. Anyone have any ideas what I can do?
My configuration.yaml file looks like this (though it’s not been changed since I set it up):
homeassistant:
        latitude: 55.837486
        longitude: -13.621976
        unit_system: metric
        time_zone: Europe/London
        elevation: 302
discovery:
history:
logbook:
updater:
sun:
frontend:
conversation:
http:
        api_password: ABC123
media_player:
tts:
        - platform: google
Thank you for any help/advise
you don’t have anything under “media_player:” try to either remove it or add the “cast” platform to it then restart home assistant and see if it detects it.
thanks, I’ve added:
media_player:
  - platform: cast
    host: 192.168.0.123
Also tried without the host line, but I get:
[32m2018-01-09 17:22:42 INFO (SyncWorker_7) [pychromecast] Querying device statuse[0m
e[32m2018-01-09 17:22:42 INFO (SyncWorker_7) [pychromecast] Querying device statuse[0m
e[32m2018-01-09 17:22:42 INFO (SyncWorker_0) [pychromecast] Querying device statuse[0m
e[32m2018-01-09 17:22:43 INFO (SyncWorker_0) [pychromecast] Querying device statuse[0m
e[33m2018-01-09 17:22:47 WARNING (MainThread) [homeassistant.components.media_player] Setup of platform cast is taking over 10 seconds.e[0m
e[31m2018-01-09 17:23:01 ERROR (SyncWorker_7) [pychromecast.socket_client] Failed to connect, retrying in 5.0se[0m
e[31m2018-01-09 17:23:01 ERROR (SyncWorker_0) [pychromecast.socket_client] Failed to connect, retrying in 5.0se[0m
What version of home assistant are you using? Try to remove the host entry as well see if it will auto discover the device.
0.60.0
I’ve tried without host too
more details from the log if it helps?
edited just to show anything relating to “cast” or “media_player”
[32m2018-01-09 18:18:01 INFO (MainThread) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player[0m
[32m2018-01-09 18:18:01 INFO (MainThread) [homeassistant.loader] Loaded media_player.cast from homeassistant.components.media_player.cast[0m
[32m2018-01-09 18:18:01 INFO (MainThread) [homeassistant.loader] Loaded discovery from homeassistant.components.discovery[0m
[32m2018-01-09 18:18:01 INFO (MainThread) [homeassistant.setup] Setting up media_player[0m
[32m2018-01-09 18:18:01 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.cast[0m
[33m2018-01-09 18:18:11 WARNING (MainThread) [homeassistant.setup] Setup of media_player is taking over 10 seconds.[0m
[33m2018-01-09 18:18:11 WARNING (MainThread) [homeassistant.components.media_player] Setup of platform cast is taking over 10 seconds.[0m
[31m2018-01-09 18:18:25 ERROR (SyncWorker_4) [pychromecast.socket_client] Failed to connect, retrying in 5.0s[0m
[31m2018-01-09 18:19:01 ERROR (MainThread) [homeassistant.components.media_player] Setup of platform cast is taking longer than 60 seconds. Startup will proceed without waiting any longer.[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_on>[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_off>[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=toggle>[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_up>[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_down>[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play_pause>[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play>[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_pause>[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_stop>[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_next_track>[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_previous_track>[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=clear_playlist>[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_set>[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_mute>[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_seek>[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=select_source>[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=play_media>[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=shuffle_set>[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.setup] Setup of domain media_player took 60.4 seconds.[0m
[32m2018-01-09 18:19:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=media_player>[0m
[32m2018-01-09 18:19:13 INFO (MainThread) [homeassistant.components.discovery] Found new service: google_cast {'host': '192.168.0.123', 'port': 8009, 'hostname': 'e83a6f70-0eEDITED-678c20f108cd.local.', 'properties': {'id': 'e83a6f700eEDITED894678c20f108cd', 'cd': '23302EC23F8AEDITED01C74E4E5', 'rm': '793A617F7E741FED', 've': '05', 'md': 'Google Home', 'ic': '/setup/icon.png', 'fn': 'Lounge speaker', 'ca': '2052', 'st': '0', 'bs': 'FA8FCA32444A', 'nf': '1', 'rs': False}}[0m
[32m2018-01-09 18:19:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event platform_discovered[L]: service=load_platform.media_player, platform=cast, discovered=host=192.168.0.123, port=8009, hostname=e83a6f70-0e6EDITED4-678c20f108cd.local., properties=id=e83a6f700e6EDITED0f108cd, cd=23302EC2EDITEDAE01C74E4E5, rm=793A617F7E741FED, ve=05, md=Google Home, ic=/setup/icon.png, fn=Lounge speaker, ca=2052, st=0, bs=FA8FCA32444A, nf=1, rs=False>[0m
[32m2018-01-09 18:19:13 INFO (MainThread) [homeassistant.components.discovery] Found new service: google_cast {'host': '192.168.0.99', 'port': 8009, 'hostname': '192-168-0-99.local.', 'properties': {'id': '09d5436a71494d918e38a30c44421eae', 'ic': '/setup/icon.png', 'ca': '5', 'md': 'CastReceiver1', 've': '04', 'rrv': '1.01', 'st': '0', 'rmodel': 'CastReceiver1,1', 'fn': 'M8S-99', 'rsv': '1.00'}}[0m
[32m2018-01-09 18:19:13 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.cast[0m
[32m2018-01-09 18:19:18 INFO (SyncWorker_7) [pychromecast] Querying device status[0m
[32m2018-01-09 18:19:18 INFO (SyncWorker_0) [pychromecast] Querying device status[0m
[33m2018-01-09 18:19:23 WARNING (MainThread) [homeassistant.components.media_player] Setup of platform cast is taking over 10 seconds.[0m
[31m2018-01-09 18:19:37 ERROR (SyncWorker_7) [pychromecast.socket_client] Failed to connect, retrying in 5.0s[0m
it looks like it found 2 cast devices, you don’t see any thing under the states tab?
this is my states:
the other is an Android box connected to the TV but that never showed up in the past
Here you can see “lounge speaker” (Google Home) was working OK this morning, nothing changed since then except PC and router getting rebooted (and since I noticed problems I’ve rebooted GHome too)
it looks like you may need to reconfigure your plex server…the configurator will only show up if thats the case. I dont have that state in my states list anymore.
have done that
states
Hmmmm, I have it all working now. I uninstalled the casting app on my android box and it’s all good.
Thank you very much for your help and being patient with me
No problem I was about to ask about that “castReciever1” device :slight_smile:
