I bought Raspberry Pi with HAOS installed on an SSD. Have connected to my home network via Ethernet and it has an ip address. When I try to connect from my PC I am told connection refused. When I try to connect via HA app on iPad scanning for servers does not find anything and when I use the manual entry http://192.168.0.78:8123 it says could not connect to server NSURlErrorDomain 1004
Are you able to ping 192.168.0.78? If you can, then try to open an incognito window on your browser to see if you can connect to eliminate any potential add-on issues in your browser. If you can’t ping that address then there’s something else going on.
Is it safe to assume that address was picked up from DHCP? If not, are you sure that nothing else has the .78 address?
Ping result is
PING 192.168.0.78 (192.168.0.78): 64 data bytes
72 bytes from 192.168.0.78: seq=0 ttl=64 time=10.000 ms
72 bytes from 192.168.0.78: seq=1 ttl=64 time=0.000 ms
— 192.168.0.78 ping statistics —
3 packets transmitted, 2 packets received, 33% packet loss
round-trip min/avg/max = 0.000/5.000/10.000 ms
When I check it is the only device with that address.
Tried incognito using Chrome and get unreachable message.
This seems silly to ask, but have you tried powering off the rPi completely and back on? Also, how is your SSD connected - directly into the USB or via a hub?
Do you mean the rPi and SSD exist in the same case? Make sure you have the proper power supply then because generally you hang the SSD off of a powered USB hub to overcome any limitations with power (and this will be even more important as you add Z-Wave/Zigbee/Bluetooth dongles).
As for restarting, I would use the HA console you have there and put in host shutdown, when it’s done then pull the plug and let it sit for a minute and plug it back in again.
Not sure. I just remember being able to see observer but needing to wait close to a half hour (installing on a virtual machine with Intel I5). But if I recall, the page error I got was “connection refused” when I tried it. Just thought it might be a setup thing.
You can check the logs…
Type supervisor logs or core logs at the Linux prompt…
My money is his installer used Balena last month for the build and unless it shipped with a fresh 2022.10.x im not sure about anything. I’m laying down the image first, then troubleshooting that install if it gives me issues.
