Complex Chrismaslight Automation
Hi
Could someone please help me with an complex automation (Christmas lights)?
The external sockets should switch on when someone is at home and the Helper ChristmasMode is OFF.
But if the helper is ON and the sun has set and someone is present then the sockets should switch on until mm:hh (helper)
Not Present @ home = SWICH OFF
Present @ home & (Helper ChristmasMode) = OFF, = SWITCH ON
Present @ home & (Helper ChristmasMode) = ON, = SWTICH OFF
Present @ home & (Helper ChristmasMode) = ON, AND SUNSET, = SWITCH ON
What do I have to use as a ls trigger?
How do you prevent that after the set “helpe mm:hh” and or a change to Helper, Zone, Sun doesn’t turn the light on again unintentionally.
alias: Christmaslights
description:
  - platform: sun
    event: sunset
    offset: 0
  - platform: zone
    entity_id: device_tracker.iphone13a
    zone: zone.home
    event: enter
  - platform: zone
    entity_id: device_tracker.iphone13b
    zone: zone.home
    event: enter
  - platform: state
    entity_id:
      - input_boolean.ChristmasMode
    to: "on"
condition:
  - condition: and
    conditions:
      - condition: or
        conditions:
          - condition: zone
            zone: zone.home
          - condition: zone
            zone: zone.home
      - condition: sun
        after: sunset
      - condition: state
        entity_id: input_boolean.ChristmasMode
        state: "on"
  - service: switch.turn_on
    data: {}
      entity_id:
        - switch.0015dbe332b6a9_2
        - switch.0015dbe332b6a9_6
  - wait_for_trigger:
      - platform: time
        at: input_datetime.christmaslights_off_at
  - service: switch.turn_off
    data: {}
      entity_id:
mode: single
Thanks :slight_smile:
Before I can help you achieve your goal, I need clarification for this requirement:
Currently, your automation’s Zone Trigger only monitors when either device_tracker enters the home zone. If you want to turn off the switch when no one is present, you’ll also need to monitor when the device_tracker leaves the home zone. Did you overlook to include it or did I misunderstand your requirement for when the switch should be turned off?
Thanks in advance. If I leave the home zone, the sockets should be off.
@123 sorry for stressing (but my wife is already sharpening the knives), but can you help me?
This community currently has over 150 thousand members. If a day’s delay in responding to you is too slow, the good news is that there are tens of thousands of other users who might have more free time to help you.
Experiment with the following automation and see if it meets your needs. The choose has four conditions and each one corresponds to one of your requirements.
description:
  - platform: sun
    event: sunset
    offset: 0
  - platform: zone
    entity_id:
      - device_tracker.iphone13a
      - device_tracker.iphone13b
    zone: zone.home
    event: enter
  - platform: zone
    entity_id:
    zone: zone.home
    event: leave
  - platform: state
    to: "on"
  - platform: time
condition: []
  - variables:
      lights:
      is_home: "{{ is_state('device_tracker.iphone13a', 'home') or is_state('device_tracker.iphone13b', 'home') }}"
      is_christmas_mode: "{{ is_state('input_boolean.christmasmode', 'on') }}"
  - choose:
      - conditions:
          - '{{ is_home }}'
          - '{{ is_christmas_mode }}'
          - "{{ is_state('sun.sun', 'below_horizon') }}"
        sequence:
              entity_id: '{{ lights }}'
      - conditions:
          - '{{ is_home }}'
          - '{{ not is_christmas_mode }}'
        sequence:
      - conditions:
          - '{{ is_home }}'
        sequence:
      - conditions:
          - '{{ not is_home }}'
        sequence:
    default: []
Hi
First. I want to apologize for the stress! I’ve added it now and will see if it works the way it should tonight. I looked at the code, it’s actually quite logical, but I can’t code it myself yet…
How or where should I add a [Time Helper] to the code to switch off the sockets at the set time.
e.g. lights off at 11:00 p.m
THANKS :slight_smile:
Add a Time Trigger.
  - platform: time
    at: input_datetime.your_time_helper
Modify the choose's last conditions statement.
      - conditions:
          - '{{ not is_home or trigger.platform == 'time' }}'
        sequence:
light does not switch off at selected time.
In my logic, the first choose overwrites the light and turns it on?! Or am I misunderstanding this?
^*dont wonder I have adjusted the var (I speak German…)
    - choose:
        - conditions:
            - "{{ is_home }}"
            - "{{ is_weihnachtsbeleuchtung }}"
20:13 was set to turn off… this works, but he choose option 1
i added following code and set off time to 20:45, and it turned off :slight_smile: (but is this the right way?)
    - choose:
        - conditions:
            - "{{ is_home }}"
            - "{{ not trigger.platform == 'time' }}"
in addition, the light does not come on at sunset. but if I turn the helper off/on it works. so there should also be a problem with the trigger sun
after a long back and forth the perfect solution
alias: AuĂźensteckdosen (inkl. Weihnachtsmodus)
description: >-
  Bei Abwesenheit werden die AuĂźensteckdosen ausgeschalten, bei Anwesenheit
  eingeschalten. Wenn Weihnachtsmodus Aktiv, dann schalten die Steckdosen nur
  ein wenn jemand Zuhause ist und die Sonne untergegangen ist. Die Steckdosen
  schalten sich zur eingestellten Uhrzeit (Helper) aus.
  - platform: sun
    event: sunset
    offset: 0
  - platform: numeric_state
    entity_id: zone.home
    above: 0
  - platform: state
    entity_id:
      - input_boolean.weihnachtsbeleuchtung
    to: "on"
    below: 1
  - platform: time
    at: input_datetime.weihnachtsbeleuchtungaus_um
  - platform: state
    entity_id:
    to: "off"
condition: []
  - choose:
      - conditions:
          - condition: trigger
          - condition: time
            before: input_datetime.weihnachtsbeleuchtungaus_um
          - condition: state
            entity_id: input_boolean.weihnachtsbeleuchtung
            state: "on"
          - condition: numeric_state
            above: 0
          - condition: sun
            after: sunset
        sequence:
            data: {}
              entity_id:
                - switch.0015dbe991b6a9_2
                - switch.0015dbe991b6a9_6
      - conditions:
        sequence:
            data: {}
              entity_id:
mode: single
You have misunderstood the purpose of the Solution tag. Refer to guideline 21 in the FAQ.
You marked your own post as the Solution yet it’s based on the example I provided you eight days ago. Without that example, you wouldn’t have the basis for fulfilling your original requirements.
In addition, the example you posted appears to have fewer requirements because it no longer takes the device_trackers into account. Anyone reading the requirements you specified in your first post will be led to an alleged solution that doesn’t fulfill all of them.
Anyway, I hope you and your family enjoy the Christmas lighting.
