I try to realize a complex light automation. This Automation should include a Motion Sensor disable and a manually activation functionality.
I made a flow-chart to describe a bit easier. On the top are the triggers that are fired.
How can I change the design of the automation that the motion detection doesn’t change my input-bool (manually switched) and does not fire the the triggers on the right side.
alias: room Light Extended
description: ""
triggers:
- trigger: state
entity_id:
- binary_sensor.motion_room_motion
to: "on"
alias: Motion Detected
- alias: Motion Stopped
trigger: state
entity_id:
to: "off"
for:
hours: 0
minutes: 0
seconds: 10
- alias: Button room "Press"
device_id: 782afd20da32e65536c7xxx6e9d153df
domain: bthome
type: button
subtype: press
trigger: device
- trigger: state
entity_id:
- light.led_room_cw
to: "on"
id: switch on trigger
alias: CW on
enabled: false
- trigger: state
entity_id:
- light.led_room_ww
to: "on"
alias: WW on
enabled: false
- trigger: state
entity_id:
- light.led_room_cw
to: "off"
id: switch off trigger
alias: CW off
enabled: false
- trigger: state
entity_id:
- light.led_room_ww
to: "off"
alias: WW off
enabled: false
conditions: []
actions:
- choose:
- conditions:
- condition: and
conditions:
- condition: state
entity_id: input_boolean.room_motion_sensor_disable
state: "off"
- condition: trigger
id:
- Motion Detected
sequence:
- action: light.turn_on
metadata: {}
brightness_pct: 80
kelvin: 6419
area_id: room
- conditions:
- condition: and
conditions:
id:
- Motion Stopped
- condition: state
state: "off"
- condition: state
entity_id: input_boolean.room_light_manually
state: "off"
sequence:
- sequence:
metadata: {}
brightness_pct: 10
kelvin: 6419
area_id: room
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
- action: light.turn_off
metadata: {}
data: {}
area_id: room
- conditions:
id:
- roomButtonPress
sequence:
- if:
- condition: or
conditions:
- condition: device
type: is_on
device_id: 92a044272ac66ebbb25dde823056b841
entity_id: 5b24466d8dc1bdccca55d4c249c3c983
domain: light
- condition: device
type: is_on
device_id: 92a044272ddd6e69a25dde823056b841
entity_id: bfbadc152672555603abbbf5555fa11c
domain: light
alias: Light on?
then:
- alias: Manually on?
if:
- condition: state
state: "on"
then:
- sequence:
metadata: {}
data: {}
area_id: room
- action: input_boolean.turn_off
metadata: {}
data: {}
alias: switch off
else:
- sequence:
metadata: {}
brightness_pct: 80
kelvin: 6419
area_id: room
- action: input_boolean.turn_on
metadata: {}
data: {}
alias: Switch On
else:
- sequence:
metadata: {}
brightness_pct: 80
kelvin: 6419
area_id: room
metadata: {}
data: {}
alias: Switch On
alias: Button
- conditions:
id:
- switch on trigger
sequence:
- sequence:
metadata: {}
brightness_pct: 80
kelvin: 6419
area_id: room
metadata: {}
data: {}
alias: Switch On
- conditions:
id:
- switch off trigger
sequence:
- sequence:
metadata: {}
data: {}
area_id: room
metadata: {}
data: {}
alias: switch off
mode: restart
