Component blocking and the HX711
I’ve got an old scale project I’m trying to get going again, and I’m getting a warning that the api is taking too long.
[15:04:30][W][component:237]: Component api took a long time for an operation (576 ms).
Is there anything standing out that might be causing the issue, or is this an issue with the HX711 and I just have to live with it?
esphome:
  on_boot:
    - delay: 5s
    - logger.log:
        format: "test is %0f"
        args: [ '666']
  includes:
    - "custom_hx711.h"
  libraries:
    - "https://github.com/bogde/HX711"
ota:
  - platform: esphome
    password: !secret ota_password
esp8266:
  board: d1_mini
wifi:
  ssid: !secret wifi_ssid
  reboot_timeout: 0s
  fast_connect: true
  manual_ip:
    static_ip: 172.16.68.72
    gateway: 172.16.68.1
    subnet: 255.255.255.0
  ap:
    ssid: "Bed-Hx711B Fallback Hotspot"
    password: "3IexvKFhv5qd"
# Enable logging
logger:
  level: DEBUG
# Enable Home Assistant API
api:
  encryption:
    key: !secret api_key
captive_portal:
  - platform: hx711
    dout_pin: D2
    clk_pin: D3
    # ... Other HX711 options
    gain: 128
    update_interval: 2s
    unit_of_measurement: lbs
    filters:
      - calibrate_linear:
          - -4516200 -> 0
          - -4579200 -> 10
      - lambda: |-
          id(weight_no_tare).publish_state(x);
          return (x - id(weight_tare));
    internal: True
globals:
  - id: weight_tare
    type: float
    restore_value: False
    initial_value: '0.0'
button:
    on_press:
      - lambda: id(weight_tare) = id(weight_no_tare).state;
      - logger.log: "Hello World Tare"
  - platform: restart
    on_press:
      - logger.log: "Restart Button Hello World"
switch:
- platform: restart
  on_turn_on:
    - logger.log: "Restart Switch Hello World"
I don’t have answer to your question, but try with the built in component.
