abasel
(Andre)
1
After watching many tutorials, I see that it’s a good idea to break up my configuriton.yaml file.
As per an tutorial, I created two (both in the config folder) i.e.
- input_time.yaml
- input_boolean.yaml
In the configuration file I have:
input_boolean: !include input_boolean.yaml
input_time: !include input_time.yaml
When I check the configuration I get, “Component error: input_time - Integration ‘input_time’ not found.”
I have tried deleting and recreating but I just can’t see what I am doing wrong. Even having input_time.yaml empty returns an error.
I then tried adding another file and that too also gave a similar error.
koying
(Chris B)
2
Well, there is no input_time
integration, as the error message says.
You surely have no input_time:
line in your original configuration.yaml
pedolsky
(Pedolsky)
3
… it’s not in the right place. In which directory are your !include
files?
abasel
(Andre)
5
That’s the thing, there is ![:frowning: :frowning:](https://community.home-assistant.io/images/emoji/twitter/frowning.png?v=12)
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
homeassistant:
customize: !include customize.yaml
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: //ssl/privkey.pem
ip_ban_enabled: true
login_attempts_threshold: 5
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
# Example configuration.yaml entry for the Telegram Bot
telegram_bot:
- platform: polling
api_key: !secret telegram_api_key
allowed_chat_ids:
- !secret telegram_chat_id1
spotify:
client_id: !secret spotify_client_id
client_secret: !secret spotify_client_secret
notify:
- platform: telegram
chat_id: !secret telegram_chat_id1
template:
- binary_sensor:
- name: "Downstairs"
state: "{{ is_state('device_tracker.downstairs', 'home') }}"
device_class: connectivity
icon: mdi:wifi
- name: "Upstairs"
state: "{{ is_state('device_tracker.upstairs', 'home') }}"
icon: mdi:wifi```
Troon
(Troon)
6
OK, so where did it come from? If you didn’t type it, how did you install HA?
abasel
(Andre)
7
Awesome, thanks for that… that was doing my head in.
In the configuration.yaml file
input_datetime: !include input_time.yaml
