My Muse Luxe speaker was working fine with HomeAssistant until recently. Now when I use the wake word and send a voice command HomeAssistant executes everything and tries to play the spoken response on the speaker. However I can’t hear anything from the speaker and the log shows:
[19:49:21][W][component:237]: Component i2s_audio.media_player took a long time for an operation (57 ms).
[19:49:21][W][component:238]: Components should block for at most 30 ms.
[19:49:21][W][component:237]: Component i2s_audio.media_player took a long time for an operation (56 ms).
[19:49:21][W][component:237]: Component i2s_audio.media_player took a long time for an operation (59 ms).
[19:49:22][W][component:237]: Component i2s_audio.media_player took a long time for an operation (512 ms).
[19:49:22][W][component:238]: Components should block for at most 30 ms.
[19:49:22][W][component:237]: Component i2s_audio.media_player took a long time for an operation (508 ms).
[19:49:24][D][voice_assistant:514]: State changed from STREAMING_RESPONSE to IDLE
I searched all kinds of forums but can’t figure out what the problem is and how to fix it.
When I click on “Edit” in the ESPHome add-on the following yaml shows:
esphome:
friendly_name: MuseLuxe
name_add_mac_suffix: false
min_version: 2023.10.1
on_boot:
then:
- output.turn_on: dac_mute
- light.turn_on:
effect: slow_pulse
red: 100%
green: 60%
blue: 0%
esp32:
board: esp-wrover-kit
framework:
type: arduino
logger:
api:
encryption:
key: "REDACTED"
services:
- service: start_va
then:
- voice_assistant.start
- service: stop_va
then:
- voice_assistant.stop
i2c:
sda: GPIO18
scl: GPIO23
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Museluxe Fallback Hotspot"
password: "REDACTED"
captive_portal:
improv_serial:
external_components:
- source: github://RASPIAUDIO/esphomeLuxe@main
components: [es8388]
refresh: 0s
es8388:
globals:
- id: wifi_connected
type: bool
initial_value: "false"
restore_value: false
interval:
- interval: 1s
then:
- if:
condition:
and:
- lambda: "return !id(wifi_connected);"
- wifi.connected:
then:
- globals.set:
value: "true"
- light.turn_on:
effect: pulse
red: 0%
green: 100%
blue: 0%
- delay: 1s
- light.turn_off: top_led
output:
- platform: gpio
pin: GPIO21
inverted: true
i2s_audio:
- i2s_lrclk_pin: GPIO25
i2s_bclk_pin: GPIO5
media_player:
- platform: i2s_audio
dac_type: external
i2s_dout_pin: GPIO26
mode: stereo
on_state:
if:
condition:
media_player.is_playing:
then:
output.turn_off: dac_mute
else:
on_pause:
- media_player.stop
microphone:
i2s_din_pin: GPIO35
adc_type: external
pdm: false
voice_assistant:
microphone: luxe_microphone
media_player: luxe_out
use_wake_word: true
on_listening:
- light.turn_on:
blue: 100%
red: 0%
green: 0%
brightness: 100%
effect: pulse
on_tts_start:
- light.turn_on:
blue: 60%
red: 20%
green: 20%
effect: none
on_tts_end:
- media_player.play_media: !lambda return x;
- light.turn_on:
blue: 60%
red: 20%
green: 20%
effect: pulse
# This is useful when you want to stream the response on another media_player
# - homeassistant.service:
# service: media_player.play_media
# data:
# entity_id: media_player.some_speaker
# media_content_id: !lambda 'return x;'
# media_content_type: music
# announce: "true"
on_client_connected:
- if:
condition:
- switch.is_on: use_wake_word
then:
- voice_assistant.start_continuous:
on_client_disconnected:
- if:
condition:
then:
- voice_assistant.stop:
on_end:
- delay: 100ms
- wait_until:
not:
media_player.is_playing: luxe_out
- script.execute: reset_led
on_error:
- light.turn_on:
blue: 0%
red: 100%
green: 0%
effect: none
- delay: 1s
- script.wait: reset_led
- lambda: |-
if (code == "wake-provider-missing" || code == "wake-engine-missing") {
id(use_wake_word).turn_off();
- platform: adc
pin: GPIO33
device_class: voltage
unit_of_measurement: "V"
accuracy_decimals: 2
state_class: measurement
entity_category: diagnostic
update_interval: 15s
attenuation: auto
filters:
- multiply: 2 # https://forum.raspiaudio.com/t/esp-muse-luxe-bluetooth-speaker/294/12
- exponential_moving_average:
alpha: 0.2
send_every: 2
- delta: 0.002
on_value:
then:
- sensor.template.publish:
state: !lambda "return x;"
device_class: battery
unit_of_measurement: "%"
accuracy_decimals: 0
filters:
- calibrate_polynomial:
degree: 3
datapoints:
- 4.58 -> 100.0
- 4.5 -> 97.1
- 4.47 -> 94.2
- 4.44 -> 88.4
- 4.42 -> 82.7
- 4.41 -> 76.9
- 4.41 -> 71.1
- 4.37 -> 65.3
- 4.35 -> 59.5
- 4.31 -> 53.8
- 4.28 -> 48.0
- 4.26 -> 42.2
- 4.23 -> 36.4
- 4.21 -> 30.6
- 4.19 -> 24.9
- 4.16 -> 19.1
- 4.1 -> 13.3
- 4.07 -> 10.4
- 4.03 -> 7.5
- 3.97 -> 4.6
- 3.82 -> 1.7
- 3.27 -> 0.0
- lambda: return clamp(x, 0.0f, 100.0f);
binary_sensor:
- platform: gpio
pin:
number: GPIO19
inverted: true
mode:
input: true
pullup: true
on_click:
- media_player.volume_up: luxe_out
- platform: gpio
pin:
number: GPIO32
inverted: true
mode:
input: true
pullup: true
on_click:
- media_player.volume_down: luxe_out
- platform: gpio
pin:
number: GPIO12
inverted: true
mode:
input: true
pullup: true
on_click:
- if:
condition:
switch.is_off: use_wake_word
then:
- if:
condition: voice_assistant.is_running
then:
else:
- voice_assistant.start:
else:
- delay: 1s
light:
- platform: esp32_rmt_led_strip
pin: GPIO22
chipset: SK6812
num_leds: 1
rgb_order: grb
rmt_channel: 0
default_transition_length: 0s
gamma_correct: 2.8
effects:
- pulse:
transition_length: 250ms
update_interval: 250ms
- pulse:
transition_length: 1s
update_interval: 2s
script:
- id: reset_led
then:
- if:
condition:
then:
- light.turn_on:
blue: 100%
red: 100%
green: 0%
brightness: 100%
effect: none
else:
switch:
name: Use Wake Word
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
on_turn_on:
- lambda: id(va).set_use_wake_word(true);
- if:
condition:
not:
- voice_assistant.is_running
then:
on_turn_off:
- lambda: id(va).set_use_wake_word(false);
