"Component not found: customize"
When I run check_config I get this:
Testing configuration at /root/.homeassistant
16-11-05 13:11:21 ERROR (Thread-1) [homeassistant.loader] Unable to find component customize
Failed config
General Errors:
- Component not found: customize
Can’t find it anywhere, should it be downloaded automatically or anything?
There is an error in your config file.
“Customize” should be indented under “homeassistant” like this:
homeassistant:
  unit_system: metric
  # etc
  customize:
Thanks, I changed the entry - works now :slight_smile:
Cheers!
Does it have to be there as you mentioned, even though it’s in the footer like:
customize: !include customize.yaml ???
Thank you!
Antonio
I don’t know what in the footer means in this context, but customize is an option of homeassistant, so must be indented as described above.
