Component not found: how can i solve?
Hello to all,
I have this problem with integrations, it returns the error:
Component not found: qvr_pro
Component not found: melcloud
Invalid config for [automation]: required key not provided @ data[‘action’]. Got None
required key not provided @ data[‘trigger’]. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/
Component not found: samsungtv
Schermata 2020-04-17 alle 16.51.58
how can i solve?
Luca
your error is
You have a bad automation in your configuration
Solving it will be difficult because you’re not getting a line or character number. You’ll have to go through your files by hand and find which one is missing an action section.
Hi Luca,
welcome in the forum.
Did your automation run ever before?
Check if you do find the components somewhere in hass which are not found.
Or in the in the developer-tools corner (states).
Could also be a connection error to the components. Are they online?
And seems to be an error in your automation. Formatting - syntax ist necessary.
