Am i missing something? I’m trying to add a timer to configuration.yaml, and have copied the line below from the timer component documentation page:
timer:
timer:
duration: '00:01:00'
…but when i click the Check Config button i’m getting this:
Failed config
General Errors:
- Component not found: timer
- Setup failed for timer: Component not found.
What am I missing?
I’d say its because you have ‘timer’ under ‘timer’. Call your timer something other than ‘timer’.
Timer was introduced in 0.57 . Do you have your HA version up to date?
@sparkydave you may very well be right, but as I said that’s literally copied from the HA documentation so I’d expect that to work
@danichispa I sure don’t, I’m on 0.56 so I bet that’s it. Thanks!
good point. I had scrolled down further where they call the timer ‘test’. I hadnt noticed it being called ‘timer’ at the top. My bad. I would imagine an upgrade will get it working ![:grin: :grin:](https://community.home-assistant.io/images/emoji/twitter/grin.png?v=9)
![image](//community-assets.home-assistant.io/original/3X/8/f/8f529b17540c925ebad8abad4038a09a277f827b.png)
