Apologize if this is not the right Category…
I have 2 Pi.Holes which I tried to setup.
Found quickly the topic where a patch is coming for that.
Changed all my configuration back to my original config for only 1 pi.hole.
Unfortunately, that did not work.
I am getting
Component pi_hole cannot be merged. Expected a dict.
error message and can’t figure out how to fix that.
Anyone any idea what I am doing wrong?
# @CCOSTAN
# Original Repo : https://github.com/CCOSTAN/Home-AssistantConfig
# PiHole ad Blocking Related Packages
# https://www.vcloudinfo.com/2019/03/revisiting-the-pi-on-pi-day-with-home-assistant.html
# YouTube Video - https://youtu.be/woA88DFlH5c
pi_hole:
- host: !secret pi_hole_1_ip_addressport
# - host: !secret pi_hole_2_ip_addressport
ssl: false
verify_ssl: false
sensor pi_hole:
# - ads_blocked_today
# - ads_percentage_today
# - dns_queries_today
# - domains_being_blocked
# - queries_cached
# - queries_forwarded
# - unique_clients
# - unique_domains
sensors:
pi_hole:
friendly_name: 'PiHole'
entity_id: []
value_template: "{{ 'Online' if is_state('device_tracker.pihole', 'home') else 'Offline' }}"
# Pi Hole DNS Template to add both sets of data together from both DNS's
# - platform: template
# sensors:
# dns_queries:
# friendly_name: "DNS Queries"
# value_template: >-
# {{ ( (states('sensor.pi_hole_dns_queries_today')|float) + (states('sensor.pi_hole_dns_queries_today_2')|float) )|round(0) }}
# sensors:
# adverts_blocked:
# friendly_name: "Adverts Blocked"
# {{ ( (states('sensor.pi_hole_ads_blocked_today')|float) + (states('sensor.pi_hole_ads_blocked_today_2')|float) )|round(0) }}
# sensors:
# percent_of_adverts_blocked:
# friendly_name: "Percent of Adverts Blocked"
# unit_of_measurement: '%'
# {{ ( (states('sensor.pi_hole_ads_percentage_blocked_today')|float) + (states('sensor.pi_hole_ads_percentage_blocked_today_2')|float) )|round(2) }}
# Pi-Hole switch
switch:
- platform: command_line
switches:
pihole_1_switch:
command_on: !secret pi_hole_1_command_on
command_off: !secret pi_hole_1_command_off
command_state: !secret pi_hole_1_command_state
value_template: "{{ value_json.status == 'enabled' }}"
# pihole_2_switch:
# command_on: !secret pi_hole_2_command_on
# command_off: !secret pi_hole_2_command_off
# command_state: !secret pi_hole_2_command_state
# value_template: "{{ value_json.status == 'enabled' }}"
group pi_hole:
pi_hole:
entities:
- sensor.pi_hole
- sensor.pi_hole_version
- sensor.pi_hole_dns_unique_clients
- sensor.pi_hole_dns_queries_today
- sensor.pi_hole_ads_blocked_today
- sensor.pi_hole_ads_percentage_today
- sensor.pi_hole_ads_percentage_blocked_today
