Hi, I am using SAIC iSMART addon to integrate my MG EV. Works great (or as good as it can, considering that this is a Chinese car with Chinese SW that it integrates against).
The add-on integrates via MQTT and I have added an MQTT lock entity, which works for displaying LOCKED / UNLOCKED states as well as setting them.
Basically,
State is in .../locked and holds a bool
Cmd is in .../locked/set and is also a bool
However, I would like to show LOCKING and UNLOCKING states, which I would have to extrapolate from a combination of the state_topic and command_topic. Straight forward logics - but how can I do that in the best way in HA?
The MQTT Lock is designed to look at just the state_topic.
Just for clarity, here’s a table of the states (true is locked):
state_topic
cmd_topic
lock state
false
false
UNLOCKED
false
true
LOCKING
true
false
UNLOCKING
true
true
LOCKED
Thanks in advance!
Note: The real reason for wanting these in-between states, is that the car does not automatically send updates, when locking. So I have to force a refresh after e.g. 30 seconds. I need something to trigger the refresh, so I get the proper state of the locks after setting it.
Did you ever resolve this? I have a very similar thing with a garage door and using two sensors to determine if the door is open, closed, opening or closing.
I can use an automation to combine both topics into one but I would rather have the entire garage door definition in one place.
@SynAckFin do you have the sensors available as entities in HA?
if so, you could bring them together in a template sensor.
I don’t know how your sensors are called and what state they use (on, off, true or false), but as an example I used sensor.door_openend and sensor.door_closed and the state ‘on’ when the sensor is active.
# state door
- trigger:
- platform: time_pattern
seconds: /5 # checking state every 5 seconds
- name: state door
state: >
{% set a = states('sensor.door_opened') %}
{% set b = states('sensor.door_closed') %}
{% if a == 'on' %} # assuming when door is open the opened-detector hase state 'on'
door opened
{% elif b == 'on' %} # assuming when door is closed the closed-detector hase state 'on'
door closed
{% else %}
door opening or closing
{% endif %}
I’ve used state changes in the sensors to generate an MQTT message that I then use as a state change topic for the cover entity. The garage door consists of 2 sensors and a 2 channel relay (open/close). It is provisioned via MQTT discovery and I was looking for a solution that could be provisioned entirely via MQTT discovery without having to manually add automations.
alias: GarageDoorFudge
description: ""
- platform: state
entity_id: binary_sensor.doorbottom_contact
to: "on"
variables:
doorstate: Opening
- platform: state
to: "off"
variables:
doorstate: Closed
- platform: state
entity_id: binary_sensor.doortop_contact
to: "on"
variables:
doorstate: Closing
- platform: state
to: "off"
variables:
doorstate: Open
condition: []
- service: mqtt.publish
metadata: {}
qos: 0
topic: z/b/c/d
payload_template: |
"top":"{{ states('binary_sensor.doortop_contact') }}",
"bottom":"{{ states('binary_sensor.doorbottom_contact') }}",
"state": "{{ doorstate }}"
mode: single
