So I use assist in first tries with ha cloud, works ok. So I would like to use whisper locally and also Piper to have all data locally. Also to have more options about the config.
I also use frigate with double take for object and face detection with a coral usb stick.
I would now like to buy or build a cheap pc that can handle face detection, whisper and piper and does need as low power as possible to run it all day.
Is it possible to run all this services from 1 machine and having only 1 gpu? Can they share it?
How do you handle it? Do you run a machine for everything or just use cloud and coral?
Hi, what hardware you ended up picking? I’m in the same boat now - Frigate with 2 Corals (dealing with 14 cameras, flawlessly) and looking to host Whisper base now for the new HA Assist satellites. I’m on Intel n5105 and upgrading to the recommended n100 doesn’t look like a big upgrade to me. Isn’t there anything better now (more horse power for the same or similar power consumption)?
Also, is out there a dedicated hardware (like Coral) for running LLMs?
