Computer temperatures while running hass on raspberry
hello everybody
I run Hass.io on Raspberry and I would like to see in the frontend my PC temperatures (cpu/hdd)
any idea? :slight_smile:
Search and you’ll find;
hi @sjee, thanks for the reply.
I did the research and came up with the same result. possibly I misunderstood it, but it looks like it refers to the raspberry cpu. am I wrong?
what I am after, is to show data coming from a PC in the network.
I use this:
For windows I use https://www.home-assistant.io/components/sensor.openhardwaremonitor/
If your PC is Linux (i have a proxmox host) install mosquito on it, and set a cron job to publish the temperature every 10 minutes.
I made a script and then use cron to run the script.
t=$(cat /sys/class/thermal/thermal_zone2/temp)
t=$(($t/1000))
mosquitto_pub -h 192.168.1.113 -u username -P password -t HostServer/temperature -m “$t”
thanks guys! I see I have many alternatives. I will try and let you know how it goes.
cheers!
My option for raspberry cpu temp in F. Sensors.yaml
  - platform: command_line
    name: Raspberry CPU Temp
    command: "cat /sys/class/thermal/thermal_zone0/temp | awk '{print ((($1*.001) * 9 / 5))+32}'"
    unit_of_measurement: "°F"
    value_template: '{{ value | round(0) }}'
