I have two devices:
Gledopto
I am using dresden elektronik zigbee adapter:
Zigbee DresdenElektronik
I have installed deCONZ add-on, and I can turn on/off/dimm gledopto driver everything works as expected.
Also when I scanned the network I found my second zigbee device Oblo Smart Dimmer.
The idea:
I want to control my gledopto via my smart dimmer switch (to communicate wireless with each other).
User scenario:
- User enters mobile application HomeAssistant (iOS) and turn on/dimm gledopto driver - WORKS
- User touch the Oblo Smart Dimmer which is mounted on wall in order to turn on light (communication with gledopto and then turn on the lights) - NOT IMPLEMENTED (because I don’t know how )
- User hold the Oblo Smart Dimmer which is mounted on wall in order to dimm light (communication with gledopto and then dimm the lights) - NOT IMPLEMENTED (because I don’t know how )
*Last two scenarios as well as turning lights off and to dimm to lower brightness
I assume I need to instal zigbee2mqtt?
