Conbee 2 connection lost
I installed Conbee 2 on a Raspberry Pi 4 which runs my Home Assistant, using the Zigbee Home Automation integration, which prompted me for something like “ usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II”
It worked very well. I successfully paired a number of Zigbee devices with the Conbee 2. Problems arose when trying to pair Xiaomi Aqara button switch. I tried using dConz and Phoscon, during which I seem to have lost connection with the Conbee. When I try to run the Zigbee Home Automation integration now, I am now offered a serial connection which does not work – see screenshot. When I run Phoscan, I get Firmware Not connected. I have located the Conbee approximately 1 m from the Raspberry Pi and other devices. I have reset many times and tried the usual restatr steps but to no avail.
Can I completely / factory reset the Conbee and start from the beginning or do I need a new device? Any other suggestions as to how I can reconnect with the Conbee?
Any help would be appreciated.
You can’t use deconz and zha at the same time.
Only one can control the conbee stick
Thanks, Sam! My problem may have arisen from installing the dConz integration when I already had ZHA integration installed. The situation now is that I cannot properly install either of those integrations as they do not seem to connect with the Conbee.
