ConBee 2-deCONZ "network was not found.."
Hi, I just update the ConBee 2 firmware as requested by the app. Now it doesn’t find the network. What should I do? I’m using a Conbee 2 with a rpi4 and SSD. Thank you!
Hi, i have the same problem, did you manage tofix it?
Sure, I solved the problem by throwing away DeConz. Now I’m using conbee2 stick with ZHA and everything works fine. The problem was on Conbee2 firmware and how DeConz managed it. I tried to manually update Conbee’s firmware with no luck then I tried to roll back but again no luck. Eventually, the solution was to rid of DeConz.
Lovely, thanks! This solved it for me. For other noobs out there, ZHA is the Zigbee Home Automation integration. Uninstalled DeConz. Tried to pair an IKEA Trådfri control outlet at had no issues at all.
