I’ve followed the instructions from every place I can find but I keep running into the part where you go to supervisor, system, host, 3 dots, hardware tab to find serial device path. First, it’s changed from what every video shows. I can’t find conbee anywhere in the new hardware section.
Specs: Home assistant full install on raspberry pi 4, no docker or other more complicated setup (I’m new to Linux). Conbee is plugged into a black usb port, and using a USB extension (per instructions). I am trying to install ZHA to run zigbee stuff, nothing crazy.
Forgot to mention, conbee 2 works. I tested and updated firmware on the conbee on a windows box. I even paired an aqara motion sensor to make sure everything worked. I have now thought to try using the blue usb ports with no luck.
Have a look at supervisor → 3 dots → hardware. Look if theres ttyACM0 present, for me its the conbee2.
If you see the stick present, go to settings → devices and integrations → add integration → zha. There you should get a popup if its detected. If not, try rebooting
In case this post helps anyone with the same problem, I had an issue with the rPi. Once I replaced it, and got HA running, it worked immediately. @tenn0, thank you for your reply.
