Newbie, tried to install via r/pi4, for the most part followed ConBee 2 Home Assistant video by dzeykop, 2 years ols so some differences. Anyway managed to download deCONZ and get to the phoscon page but is reporting that firmware is not connected, previously I believe it was there but looked like it needed an update which I executed - currently not operating/discovering anything - log information reads as follows. Any help would be appreciated - I am technically minded but not familiar with inner workings of HA, thanks, A
Serial ‘/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2474053-if00’ connection lost unexpectedly: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
22:22:34 – (WARNING) /usr/local/lib/python3.9/site-packages/zigpy_deconz/api.py - message first occurred at 22:15:25 and shows up 11 times
Lost serial connection: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
22:22:34 – (ERROR) /usr/local/lib/python3.9/site-packages/zigpy_deconz/uart.py - message first occurred at 22:15:25 and shows up 11 times
Couldn’t start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator
22:22:07 – (ERROR) Zigbee Home Automation - message first occurred at 22:15:25 and shows up 4 times
Couldn’t start application
22:22:07 – (ERROR) /usr/local/lib/python3.9/site-packages/zigpy/application.py - message first occurred at 22:15:25 and shows up 9 times
No response to ‘Command.read_parameter’ command with seq id ‘0x02’
22:22:07 – (WARNING) /usr/local/lib/python3.9/site-packages/zigpy_deconz/api.py - message first occurred at 22:15:25 and shows up 4 times
22:20:45 – (ERROR) Zigbee Home Automation - message first occurred at 22:15:31 and shows up 5 times
Config entry ‘ConBee II - /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2474053-if00, s/n: DE2474053 - dresden elektronik ingenieurtechnik GmbH - 1CF1:0030’ for zha integration not ready yet; Retrying in background
22:15:25 – (WARNING) config_entries.py
