2023-01-24 16:33:03.388 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2023-01-24 16:33:03.577 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=1 from 2023-01-23 10:44:09.848706)
2023-01-24 16:38:57.570 ERROR (MainThread) [zigpy.application] Couldn't start application
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 146, in startup
await self.initialize(auto_form=auto_form)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 125, in initialize
await self.permit(0)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 1016, in permit
await zigpy.zdo.broadcast(
File "/usr/local/lib/python3.10/site-packages/zigpy/device.py", line 522, in broadcast
return await app.broadcast(
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 778, in broadcast
await self.send_packet(
File "/usr/local/lib/python3.10/site-packages/zigpy_deconz/zigbee/application.py", line 423, in send_packet
raise zigpy.exceptions.DeliveryError(
zigpy.exceptions.DeliveryError: Failed to deliver packet: <TXStatus.MAC_CHANNEL_ACCESS_FAILURE: 225>
2023-01-24 16:38:57.617 WARNING (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 1 of 3)
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 174, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 169, in new
await app.startup(auto_form=auto_form)
2023-01-24 16:39:00.866 ERROR (MainThread) [zigpy.application] Couldn't start application
2023-01-24 16:39:00.877 WARNING (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 2 of 3)
2023-01-24 16:39:04.148 ERROR (MainThread) [zigpy.application] Couldn't start application
2023-01-24 16:39:04.158 WARNING (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 3 of 3)
2023-01-24 16:39:04.162 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry ConBee II for zha
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 382, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 111, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 189, in async_initialize
raise exc
2023-01-24 16:39:24.695 ERROR (MainThread) [zigpy.application] Couldn't start application
2023-01-24 16:39:24.707 WARNING (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 1 of 3)
2023-01-24 16:39:27.929 ERROR (MainThread) [zigpy.application] Couldn't start application
2023-01-24 16:39:27.939 WARNING (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 2 of 3)
2023-01-24 16:39:31.206 ERROR (MainThread) [zigpy.application] Couldn't start application
2023-01-24 16:39:31.217 WARNING (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 3 of 3)
2023-01-24 16:39:31.220 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry ConBee II for zha
raise exc
2023-01-24 16:56:15.449 ERROR (MainThread) [homeassistant] Error doing job: Task was destroyed but it is pending!
2023-01-24 16:56:15.641 ERROR (MainThread) [zigpy.application] Couldn't start application
2023-01-24 16:56:15.653 WARNING (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 1 of 3)
2023-01-24 16:56:18.939 ERROR (MainThread) [zigpy.application] Couldn't start application
2023-01-24 16:56:18.947 WARNING (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 2 of 3)
2023-01-24 16:56:22.225 ERROR (MainThread) [zigpy.application] Couldn't start application
2023-01-24 16:56:22.233 WARNING (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 3 of 3)
2023-01-24 16:56:22.237 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry ConBee II for zha
raise exc
2023-01-24 16:56:22.249 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1085, in async_setup
raise OperationNotAllowed(
homeassistant.config_entries.OperationNotAllowed: The config entry ConBee II (zha) with entry_id 331f67205f6a77e71ecfa1889d226c8a cannot be setup because is already loaded in the ConfigEntryState.SETUP_ERROR state
Same for me, devices that were previously connected are working fine, but i have 1 device that fell off the network last night and a new replacement device today (because i didnt think my conbee stick was failing) cant be found.
Help?
i fixed mine, for some reason even though items were still paired i never thought that these devices im trying to connect were weak and couldnt reach the stick. As soon as i moved it out of the cupboard on an even longer extension cable they connected straight away.
@spasypaddy the conbee might have very high range, but it is limited. And the more non air is in the line of sight between your stick and any device the shorter the range gets. So Having such things in the cupboard is never a good idea Then: if your lqi is low for some devices, add routers (main power connected devices such as smart plugs). Adding routers might make it necessary to repair your devices to re-check which is the better route to your coordinator.
@peter10 You may describe what your problem is and how you came there, there so many questions potentially no one is interessted in reading hundreds of lines of logs to find out it self to help you.
But you might read the first line yourself and start searching how to fix this at first.
