I have tried to install hassio in virtualbox according to The Hook ups instructions, and it works well.
https://www.youtube.com/watch?v=vnie-PJ87Eg
I connected my conbee II in my computer, added the usb device in virtualbox and started it. Under supervisor → System → hardware I’ll could now see my conbee stick as a serial by-id adress like this.
/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_XXXXXXXX-if00
I installed decons and everything worked fine. I’ll then restarted everything and the virtualbox started with the vmservice. Then the conbee stick wasn’t found anymore, under supervisor → System → hardware the serial by-id adress didn’t show anymore. so i tried with
/dev/ttyS0
instead which worked great even through vmservice. I’m gonna install both a RF-Link anda Z-stick to it so I would want to use the serial by-id adress instead of the /dev/ttyXX
adresses. How can I do this?
Another thing I would want to do is to access my onboard bluetooth in my hassio so i can connect some miflora sensors and use bluetooth devicetracker. How do I do this?
My computer is a asus VM62 with windows 10.
Thank you!
