I have a problem, and cant figure out what the problem is.
I am running Home Assistant on my Synology DS918+ on Virtual Machine and I am trying to get my Conbee II stick to work.
I did put the USB in the back of the Synology.
In de VM I have turned on the USB 2.0 option, to ensure there are no problems with the USB 3.0 port.
I am running DeCONZ latest version and running the latest firmware on the Conbee II stick V2.05.88
I am using the /dev/serial/by-id/ option in the deCONZ config
Rebooted the Synology, Home Assistant and deCONZ multiple times.
I can acces Phoscon in Home Assistant, but I cant add devices.
I really dont know what to do next, so frustrating.
Crazy enough the USB extension cable does work.
For some reason, you can see the stick on a USB 3.0 port and everything (looks) normal. But it just can’t find any device on a USB 3.0 port.
Strangely enough, it did work on my pc with a USB 3.0 cable.
The simple advice from my side, just use an extension cable, so you know for sure that this can’t cause any issues
The only downside I have (but that’s just a VM thing) is that it uses more CPU than docker.
But docker was crashing way too often, and I really like the full Hassio.
I am currently doing some energy consumption tracking on my NAS (DS918+), to see if I am better off buying a raspberry pi 4!
