I have exactly the same problem. I have the SSH add-on which doesn’t work with the firmware updating procedure, so I also plugged it in to a Windows computer with the same result as you.
Did you try to update using the web interface (phoscon app)? You should be able to access this via your ip address without any port. If not try: your_ip/pwa
I could update via the web interface to firmware 26240500 (version 2.05.40 / 8.10.2018).
I had the same issue. Updated in windows to 0x261f0500 but had to set up SSH in order to update to 0x262d0500. Once SSH is setup it easy to update. Since you probably will update more than once i think is a good idea to learn how to update directly in hass.
I am using the deconz addon included with home assistant. Switched from Marthoc github. Nevertheless now my conbee stick is identified as raspbee in product in phoscon. Is this a problem, will this be a problem going forward. FW upgrade via phoscon ui will be available for the rpi / hassio / conbee setup going forward?
I have the same problem, with the addon phoscon gui. My conbee has version 261F0500. Every time I start it it says I sould upgrade to 26330500.
So I do, but the next time I start it it’s the same all over again. I’m running deCONZ version 3.9
Anyone find a fix for this. I have version 26050500 and it keeps saying 26330500 is available. I update and it says update is successful then next time I go in it shows the older version and that an update is available. I had an aeotec stick, unplugged that and its not helped
I get this in the log:
13:10:21:204 dev /dev/ttyAMA0
13:10:21:205 GW firmware version: 0x26050500
13:10:21:205 GW firmware version shall be updated to: 0x26330500
13:10:59:198 Current channel 11
13:11:59:200 Current channel 11
13:12:31:204 dev /dev/ttyAMA0
13:12:31:204 GW firmware version: 0x26050500
13:12:31:204 GW firmware version shall be updated to: 0x26330500
13:12:59:200 Current channel 11
13:13:59:201 Current channel 11
13:14:29:728 New websocket 127.0.0.1:40274 (state: 3)
13:14:41:056 Websocket disconnected 127.0.0.1:40274 (state: 0)
13:14:41:185 dev /dev/ttyAMA0
13:14:41:185 GW firmware version: 0x26050500
13:14:41:185 GW firmware version shall be updated to: 0x26330500
13:14:58:174 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
13:14:58:174 device state timeout ignored in state 5
13:14:58:175 device disconnected reason: 1, index: 0
13:14:58:353 GW firmware start update (device not connected)
13:14:58:627 GW firmware update exit code 255
13:14:59:153 wait reconnect 15 seconds
13:14:59:165 Wait reconnect after firmware update
13:15:00:152 wait reconnect 14 seconds
13:15:00:158 Wait reconnect after firmware update
13:15:01:152 wait reconnect 13 seconds
13:15:01:164 Wait reconnect after firmware update
13:15:01:644 New websocket 127.0.0.1:40578 (state: 3)
13:15:02:153 wait reconnect 12 seconds
13:15:02:164 Wait reconnect after firmware update
13:15:03:152 wait reconnect 11 seconds
13:15:03:163 Wait reconnect after firmware update
13:15:04:152 wait reconnect 10 seconds
13:15:04:164 Wait reconnect after firmware update
13:15:05:152 wait reconnect 9 seconds
13:15:05:164 Wait reconnect after firmware update
13:15:06:153 wait reconnect 8 seconds
13:15:06:164 Wait reconnect after firmware update
13:15:07:152 wait reconnect 7 seconds
13:15:07:163 Wait reconnect after firmware update
13:15:08:152 wait reconnect 6 seconds
13:15:08:164 Wait reconnect after firmware update
13:15:08:201 dev /dev/ttyAMA0
13:15:09:153 wait reconnect 5 seconds
13:15:09:159 Wait reconnect after firmware update
13:15:10:152 wait reconnect 4 seconds
13:15:10:164 Wait reconnect after firmware update
13:15:11:153 wait reconnect 3 seconds
13:15:11:159 Wait reconnect after firmware update
13:15:12:152 wait reconnect 2 seconds
13:15:12:157 Wait reconnect after firmware update
13:15:13:152 wait reconnect 1 seconds
13:15:13:164 Wait reconnect after firmware update
13:15:14:158 Wait reconnect after firmware update
13:15:15:164 Wait reconnect after firmware update
13:15:16:164 Wait reconnect after firmware update
13:15:17:164 Wait reconnect after firmware update
13:15:18:164 Wait reconnect after firmware update
13:15:19:165 Wait reconnect after firmware update
13:15:20:164 Wait reconnect after firmware update
13:15:21:164 Wait reconnect after firmware update
13:15:22:165 Wait reconnect after firmware update
13:15:23:164 Wait reconnect after firmware update
13:15:24:164 Wait reconnect after firmware update
13:15:25:164 Wait reconnect after firmware update
13:15:26:158 Wait reconnect after firmware update
13:15:27:164 Wait reconnect after firmware update
13:15:28:166 Wait reconnect after firmware update
13:15:29:164 Wait reconnect after firmware update
13:15:30:165 Wait reconnect after firmware update
13:15:31:164 Wait reconnect after firmware update
13:15:32:165 Wait reconnect after firmware update
13:15:33:159 Wait reconnect after firmware update
13:15:34:159 Wait reconnect after firmware update
13:15:35:159 Wait reconnect after firmware update
13:15:36:164 Wait reconnect after firmware update
13:15:37:165 Wait reconnect after firmware update
13:15:38:165 Wait reconnect after firmware update
13:15:39:165 Wait reconnect after firmware update
13:15:40:162 Wait reconnect after firmware update
13:15:41:160 Wait reconnect after firmware update
13:15:42:165 Wait reconnect after firmware update
13:15:43:158 Wait reconnect after firmware update
13:15:44:159 Wait reconnect after firmware update
13:15:45:159 Wait reconnect after firmware update
13:15:46:165 Wait reconnect after firmware update
13:15:47:164 Wait reconnect after firmware update
13172.30.32.2 - - [30/Apr/2020:13:16:43 +0100] "GET /api/2127058B02/config?_=1588248886977 HTTP/1.1" 200 2102 "https://themattbarnes.duckdns.org/api/hassio_ingress/FAjknEM6t1-jCnyYc4Ntc5DsOHQFuKYCvHtuclKrR30/pwa/settings-gateway2.html?_v=6d09411ad6487410951338523de2be4014e9f49e,3,4,13&gwid=00212EFFFF04102E" "Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.113 Safari/537.36"
172.30.32.2 - - [30/Apr/2020:13:16:48 +0100] "GET /api/2127058B02/config?_=1588248886978 HTTP/1.1" 200 2102 "https://themattbarnes.duckdns.org/api/hassio_ingress/FAjknEM6t1-jCnyYc4Ntc5DsOHQFuKYCvHtuclKrR30/pwa/settings-gateway2.html?_v=6d09411ad6487410951338523de2be4014e9f49e,3,4,13&gwid=00212EFFFF04102E" "Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.113 Safari/537.36"
172.30.32.2 - - [30/Apr/2020:13:16:53 +0100] "GET /api/2127058B02/config?_=1588248886979 HTTP/1.1" 200 2102 "https://themattbarnes.duckdns.org/api/hassio_ingress/FAjknEM6t1-jCnyYc4Ntc5DsOHQFuKYCvHtuclKrR30/pwa/settings-gateway2.html?_v=6d09411ad6487410951338523de2be4014e9f49e,3,4,13&gwid=00212EFFFF04102E" "Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.113 Safari/537.36"
172.30.32.2 - - [30/Apr/2020:13:16:58 +0100] "GET /api/2127058B02/config?_=1588248886980 HTTP/1.1" 200 2102 "https://themattbarnes.duckdns.org/api/hassio_ingress/FAjknEM6t1-jCnyYc4Ntc5DsOHQFuKYCvHtuclKrR30/pwa/settings-gateway2.html?_v=6d09411ad6487410951338523de2be4014e9f49e,3,4,13&gwid=00212EFFFF04102E" "Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.113 Safari/537.36"
172.30.32.2 - - [30/Apr/2020:13:17:04 +0100] "GET /api/2127058B02/config?_=1588248886981 HTTP/1.1" 200 2102 "https://themattbarnes.duckdns.org/api/hassio_ingress/FAjknEM6t1-jCnyYc4Ntc5DsOHQFuKYCvHtuclKrR30/pwa/settings-gateway2.html?_v=6d09411ad6487410951338523de2be4014e9f49e,3,4,13&gwid=00212EFFFF04102E" "Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.113 Safari/537.36"
172.30.32.2 - - [30/Apr/2020:13:17:09 +0100] "GET /api/2127058B02/config?_=1588248886982 HTTP/1.1" 200 2102 "https://themattbarnes.duckdns.org/api/hassio_ingress/FAjknEM6t1-jCnyYc4Ntc5DsOHQFuKYCvHtuclKrR30/pwa/settings-gateway2.html?_v=6d09411ad6487410951338523de2be4014e9f49e,3,4,13&gwid=00212EFFFF04102E" "Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.113 Safari/537.36"
172.30.32.2 - - [30/Apr/2020:13:17:13 +0100] "GET /api/2127058B02/config?_=1588248886983 HTTP/1.1" 200 2102 "https://themattbarnes.duckdns.org/api/hassio_ingress/FAjknEM6t1-jCnyYc4Ntc5DsOHQFuKYCvHtuclKrR30/pwa/settings-gateway2.html?_v=6d09411ad6487410951338523de2be4014e9f49e,3,4,13&gwid=00212EFFFF04102E" "Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.113 Safari/537.36"
172.30.32.2 - - [30/Apr/2020:13:17:16 +0100] "GET /websocket HTTP/1.1" 101 0 "-" "Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.113 Safari/537.36"
