Conbee, Deconz Xiaomi Vibration sensor issues
Yes. Deconz developers changed how it gets values reported so I changed it to a sensor. If you have other sensors like these you might need to pair them again to get the new binding
Any news on changing the sensitivity in Deconz?
I see that it is possible to change the sensitivity in zigbee2mqtt but I want to continue using Deconz.
I don’t know the parameter but you can use the deconz service to configure your sensor. If you know the parameter you can reconfigure any device in deconz
I managed to change the sensitivity yesterday evening in about an hour without preknowledge, see my post on https://github.com/dresden-elektronik/deconz-rest-plugin/issues/1396 for links and hints.
My next step is trying to trigger an automation. My current code is below but does not work. I plan to run throw an update to latest version of HA and deconz, delete and readd the sensor and try again this evening to see if I can crack it.
Update 2019-07-06: My code started to work after update of deconz, home assistant, removing sensor (including entity register and in integration) and adding sensor again. Nice little device, now I will turn on the lights if someone knocks on the door :slight_smile: My later plan is to install a siren above the door that is trigged if noone home and someone tries to open the door with force. I will however have to verify that I don’t get to may false-psoitive detections first.
  #Test vibration sensor
- hide_entity: false
  initial_state: 'on'
  alias: Test vibration sensor
  - entity_id: binary_sensor.switch_60
    platform: state
    to: 'on'
  - service: light.turn_off
    entity_id: light.vardagsrum_litet_bord
  - service: persistent_notification.create
    data_template:
      message: '{{now().strftime(''%H:%M:%S'')}} Altandörr vibration detekterad'
Im trying to figure this device out but Im getting it as a binary_sensor and not as a sensor so I can use the events. Any advice?
My vibration sensor is also binary_sensor, and the values it sends are not updated in home assistant. It just shows “motion detected” constantly. What to do? Phoscon shows only “refreshed” timestamp and it correctly updates when sensor is touched
elif self._device.type in Vibration.ZHATYPE:
            attr[ATTR_ORIENTATION] = self._device.orientation
            attr[ATTR_TILTANGLE] = self._device.tiltangle
            attr[ATTR_VIBRATIONSTRENGTH] = self._device.vibrationstrength
You don’t get proper attributes?
I have some questions about the sensor as well, I only have a binary sensor and it doesn’t show the event id.
I thought maybe the deconz helper appdaemon would help me but that as well doesn’t get updated when moving the sensor.
How can I get the event id, is there another way?
Is the binary sensor state simply if there is any movement of the sensor the state goes ‘on’?
I know the event values from reading above.
Could you give a hint how to configure the sensitivity in zigbee2mqtt? Can’t find anything in the documentation :-/
This thread is for deconz. There are probably similar threads that can help you
How do you get the sensor to use events. I only get it as a binary_sensor that doesnt show events?
Have you solved it?
This works for me with my sensor on the front lid of my mailbox:
- alias: Announce mailbox opened
  - entity_id: binary_sensor.vibration_8
    platform: state
    to: 'on'
  condition: []
  - service: notify.alexa_media
        - media_player.livingroom_echo_dot
        - media_player.bathroom_echo_dot
        - media_player.kitchen_echo
      message: You've got real, post office type, physical, mail!
        type: tts
and by adding this sensor template I can show my partner what the temperature inside the mailbox is and if the mailperson left the lid open :slight_smile: :
  sensors:
    mailbox_temperature:
      unit_of_measurement: "°F"
      value_template: '{{ (((states.binary_sensor.vibration_8.attributes.temperature) * 9 / 5) + 32) | round(1) }}'
    mailbox_tiltangle:
      value_template: "{{ states.binary_sensor.vibration_8.attributes.tiltangle }}"
My Xiaomi vibration sensor triggers ON state only if I vigorously shake it.
Moving it, turning it, knocking on the surface it is on, or shaking it softly does not trigger vibration state.
As far as I can tell the attributes (orientation, tilt level, and vibration strength) are only updated when the vibration state is detected.
I changed the sensitivity to 1 (most sensitive), but that did not help.
Below are the output from deconz REST command:
    "config": {
        "battery": 100,
        "on": true,
        "pending": [],
        "reachable": true,
        "sensitivity": 1,
        "sensitivitymax": 21,
        "temperature": 2300
    "ep": 1,
    "etag": "306577ad80eb62725141081ae403f9e4",
    "manufacturername": "LUMI",
    "modelid": "lumi.vibration.aq1",
    "name": "Vibration Sensor",
    "state": {
        "lastupdated": "2019-11-08T05:53:58",
        "orientation": [
            2,
            -21,
            69
        "tiltangle": 360,
        "vibration": false,
        "vibrationstrength": 77
    "swversion": "20180130",
    "type": "ZHAVibration",
    "uniqueid": "00:15:8d:00:02:c3:a8:21-01-0101"
Is my Xiaomi vibration sensor defective?
Thank you.
Dunno if it’s defective but, my own observations: Mine is on the mailbox, outside because the metal mailbox kinda shields the signal. It detects vibration and movement but once detected, it goes into a rest state for 60 seconds. Temperature updates are intermittent. Always after the mailperson delivers mail, sometimes every 5 minutes, sometimes an hour… not a big deal with me because I’m not THAT concerned about the temperature of my mailbox. The sensor (mailbox) is approx. 25 meters from the Desconz receiver dongle. When the outside temp drops below 5 C… it get’s flakey.
Something weird started happening and I couldn’t get it working again. I deleted and re-added 4 XIAOMI vibration sensors but the binary sensors are not getting created on HA even though I can see the logs on HA saying:
> 2019-11-09 19:38:07 DEBUG (MainThread) [homeassistant.components.deconz] deCONZ event created: vs_right_door_living_room
> 2019-11-09 19:38:07 DEBUG (MainThread) [homeassistant.components.deconz] deCONZ event created: vs_left_window_living_room
> 2019-11-09 19:38:07 DEBUG (MainThread) [homeassistant.components.deconz] deCONZ event created: vs_right_window_living_room
> 2019-11-09 19:38:07 DEBUG (MainThread) [homeassistant.components.deconz] deCONZ event created: vs_left_door_living_room
Went everywhere (states, unused entities and even on .storage) and can’t seem to find the binary sensors at all on HA meaning I can’t control them at all.
Any ideas are appreciated.
One more thing I’ve found about the Aqura vibration sensor… if it’s not “right side up”, it’ gunna act funny. “Right side up” is where when mounted, the little reset button is facing up.
Hey everyone, hate to resurrect this, but I think I’m one of many with issues with this cheap little guy.
I am able to watch the sensor in NodeRed, display the output in the NR UI. I can see it’s detecting vibration, output the level and output when it’s last updated. But when the vibrations stops it no longer reports anything. I made the rest call in the example above through DeCONZ and set the sensitivity to 1. The only time it detected motion, ie. vibration = true is when I ran down to the washer/dryer with it. Otherwise, it doesn’t show anything. Maybe luckily, neither makes enough movement.
Works like a charm, but nothing to give notification from. Best I can do is see when it stopped updating through NodeRed and into the MQTT topics I’ve setup for each. I would love to maybe just be able to run an automation at this point X minutes after the last update. Otherwise sensitivity setting doesn’t work and it doesn’t do anything in HA other than say false and that the temperature is X.
EDIT: I listen to “deconz_event” and get nothing for any sensor.
Someone please post a simple automation example for “tilt” event.
Like this?
- alias: 'Simple tilt automation'
    - platform: event
      event_type: deconz_event
      event_data:
        event: 1009
    - service: light.turn_on
        entity_id: light.yourlight
