Thx for the tip. Well i did that and i managed to add the deconz integration but the thing is it only worked not with the IP tha home assistant is running (in my case 192.168.1.170) but with another ip that is displayed on the top right of the conbee portal. (170.30.31.2). Is this why i still cannot add the sensors???
I still get logs like this
16:10:41:578 wait reconnect 15 seconds
16:10:41:579 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
> 16:10:41:579 device state timeout ignored in state 1
> 16:10:42:579 failed to reconnect to network try=8
> 16:10:42:579 wait reconnect 14 seconds
> 16:10:43:588 wait reconnect 13 seconds
> 16:10:44:579 wait reconnect 12 seconds
> 16:10:45:581 wait reconnect 11 seconds
> 172.30.32.2 - - [15/Jul/2020:16:10:46 +0200] "GET /api/56478788EA/sensors/new?_=1594821339869 HTTP/1.1" 200 34 "https://192.168.1.170:8123/api/hassio_ingress/sewt33QOy8BcFmKWKlnCcFkh7vWmM1kk4E5KHZNrbzM/pwa/devices-sensors.html?_v=b7ac16f55294e5928993b2e19129d416f8e2e1a2,6,3,15&gwid=0000000000000000" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko)
> 16:10:46:578 wait reconnect 10 seconds
> 16:10:47:579 failed to reconnect to network try=9
Anyway i figured it out by myself:
I deleted deconz add on and installed the phsocon app on the nuc.
From there i clicked on the the ip address that corresponds to the way the nuc is connected to my home network (i.e. wlan). And from there i could get the api key and everything is working flawlessly.
can you clarify by what you mean by installed phsocon on the nuc?
how is HA installed on the NUC?
I’m running esxi on my nuc and then running hassio as a VM.
I have my deCONZ usb stick passing through to my VM, but the deCONZ add-on isn’t detecting it.
Intel Nuc with ESXI installed on it
Home Assistant running trought a VM
I’ve added the Conbee stick to the VM but I’ve got this message after. Anyone have an idea ?
When i check in the hardware section on Home Assistant, the USB stick is right there.
