ConBee II can't connect to any device anymore: try to reconnect to network try=x
Hello HA community ^^
My Combee II is unable to able to connect to any device anymore.
Though I can’t tell for sure after exact after which update this happend, they all went offline at one. I reboot, unplugged the device and the stick several time now.
My current setup
deCONZ: Current version: 6.22.0
Core 2024.1.5
Supervisor 2023.12.1
Operating System 11.4
Frontend 20240104.0
Part of the log
14:57:57:394 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2468375-if00 / serialno: DE2468375, ConBee II
14:57:59:832 failed to reconnect to network try=4
14:58:04:831 failed to reconnect to network try=5
14:58:09:832 failed to reconnect to network try=6
14:58:11:394 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2468375-if00 / serialno: DE2468375, ConBee II
14:58:14:832 try to reconnect to network try=7
14:58:19:831 try to reconnect to network try=8
Any help would be much appreciated.
This sub-forum section is meant for the built-in native ZHA integration + Zigbee devices connected to it.
deCONZ/Phoscon is a third-party Zigbee gateway solution, (just like Philips Hue Bridge, IKEA Trådfri Gateway, or Samsung SmartThings Hub), so to get support with it you should either post in the “third party integrations” sub-forum section → Third party integrations - Home Assistant Community or post upstream in that gateways/bridges/hubs manufacturer’s own community and support channels as there you should get better help → https://phoscon.de/en/support
