ConBee II cant detect new devices
Hello
I’m using ConBee II via zigbeemqtt integration, everything worked fine, but I’ve been noticing for a while that I can’t add new devices. I see older ones added, but I can’t add new ones. I also noticed that the attached devices no longer show signal strength. I tried to use ConBee II integration as well, it doesn’t detect any devices there either. Maybe someone has encountered a similar problem and how did you solve it?
I don’t have this issue but what logs say ?
Also you can put your dongle on windows machine directly and see if dongle is still ok on another system :wink:
