Today my new Conbee II arrived and I wanted to connect my “Aqara Door and Windows Sensor”
I am running Homeassistant on the latest Version thats availabe right now through a VM on Unraid.
My problem is that I cant connect any sonsors or switches. It just doesnt find them. I followed this tutorial: AQARA SENSORS IN HOME ASSISTANT (deConz and Conbee II FULL SETUP) - YouTube
Unraid Version: 6.11.0
Unraid HomeAssistant VM Config:
deCONZ config:
version: 6.16.0
deCONZ log:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/firmware.sh
[13:44:11] INFO: GCFFlasher V3_17 (c) dresden elektronik ingenieurtechnik gmbh
Path | Vendor | Product | Serial | Type
/dev/ttyACM0 | 0x1CF1 | 0x0030 | DE2487568 | ConBee II
cont-init: info: /etc/cont-init.d/firmware.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
cont-init: info: running /etc/cont-init.d/novnc.sh
cont-init: info: /etc/cont-init.d/novnc.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun deconz (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
services-up: info: copying legacy longrun otau-deconz (no readiness notification)
services-up: info: copying legacy longrun otau-ikea (no readiness notification)
services-up: info: copying legacy longrun otau-ledvance (no readiness notification)
services-up: info: copying legacy longrun websockify (no readiness notification)
s6-rc: info: service legacy-services successfully started
[13:44:12] INFO: Running the deCONZ OTA updater...
[13:44:12] INFO: Running the OSRAM LEdvance OTA updater...
[13:44:12] INFO: Websockify waiting for VNC to start
[13:44:12] INFO: Running the IKEA OTA updater...
[13:44:12] INFO: Starting VNC server (local/yes)...
[13:44:12] INFO: Starting websockify...
WebSocket server settings:
- Listen on 127.0.0.1:5901
- Flash security policy server
- Web server. Web root: /usr/share/novnc
- No SSL/TLS support (no cert file)
- proxying from 127.0.0.1:5901 to 127.0.0.1:5900
[13:44:15] INFO: deCONZ waiting for VNC to start
[13:44:15] INFO: Starting the deCONZ gateway...
libpng warning: iCCP: known incorrect sRGB profile
[13:44:17] INFO: Starting Nginx...
2022/09/24 13:44:17 [notice] 124#124: using the "epoll" event method
2022/09/24 13:44:17 [notice] 124#124: nginx/1.14.2
2022/09/24 13:44:17 [notice] 124#124: OS: Linux 5.15.67
2022/09/24 13:44:17 [notice] 124#124: getrlimit(RLIMIT_NOFILE): 1048576:1048576
2022/09/24 13:44:17 [notice] 124#124: start worker processes
2022/09/24 13:44:17 [notice] 124#124: start worker process 634
13:44:16:749 HTTP Server listen on address 0.0.0.0, port: 40850, root: /usr/share/deCONZ/webapp/
13:44:16:954 /data/.local/share/dresden-elektronik/deCONZ/config.ini exists and is writeable
13:44:16:954 /data/.local/share/dresden-elektronik/deCONZ/zll.db exists and is writeable
13:44:16:972 COM: use stable device path /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2487568-if00
13:44:16:985 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2487568-if00 / serialno: DE2487568, ConBee II
13:44:16:985 ZCLDB init file /data/.local/share/dresden-elektronik/deCONZ/zcldb.txt
13:44:17:030 DDF enabled for Gold status
13:44:17:078 parent process s6-supervise
13:44:17:078 gw run mode: normal
13:44:17:078 GW sd-card image version file does not exist: /data/.local/share/dresden-elektronik/deCONZ/gw-version
13:44:17:079 DB sqlite version 3.27.2
13:44:17:079 DB PRAGMA page_count: 46
13:44:17:079 DB PRAGMA page_size: 4096
13:44:17:079 DB PRAGMA freelist_count: 0
13:44:17:079 DB file size 188416 bytes, free pages 0
13:44:17:079 DB PRAGMA user_version: 9
13:44:17:079 DB cleanup
13:44:17:079 DB create temporary views
13:44:17:081 Started websocket server on 0.0.0.0, port: 8081
13:44:17:082 [INFO] - Found file containing button maps. Parsing data...
13:44:17:087 [INFO] - Button maps loaded.
13:44:17:087 found node plugin: libde_rest_plugin.so - REST API Plugin
13:44:17:087 found node plugin: libde_signal_plugin.so - Signal Monitor Plugin
13:44:18:160 OTAU: create 1189-001A-00102428.zigbee
13:44:18:218 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
parse error: Invalid numeric literal at line 1, column 34
13:44:18:295 dlg action: Read binding table
13:44:19:125 Skip idle timer callback, too early: elapsed 835 msec
13:44:19:235 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2487568-if00 / serialno: DE2487568, ConBee II
13:44:20:185 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2487568-if00 / serialno: DE2487568, ConBee II
13:44:22:333 Announced to internet https://phoscon.de/discover
13:44:24:138 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2487568-if00 / serialno: DE2487568, ConBee II
13:44:25:122 DEV Tick.Init: booted after 8000 seconds
13:44:27:566 device state timeout (handled)
13:44:27:647 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
13:44:32:137 GW update firmware found: /usr/share/deCONZ/firmware/deCONZ_ConBeeII_0x26720700.bin.GCF
13:44:38:123 start reconnect to network
13:44:42:138 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2487568-if00 / serialno: DE2487568, ConBee II
13:44:43:123 failed to reconnect to network try=1
13:44:46:303 device state timeout (handled)
13:44:46:383 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
13:44:48:123 failed to reconnect to network try=2
13:44:53:123 failed to reconnect to network try=3
