I have Xiaomi Aquara HUB with several wall switches, motion and window detectors, Philips hue HUB several lamps, 4 button remotes and motion detectors. Home Assistant is on RPi4 with HassOS.
Everything seams working good but then i found that i use Conbee II and get rid of philips and xiaomi hubs and can also buy ikea bulbs without needed to buy another hub.
I moved several switches, lights and sensors to deCONZ but now sometimes i have up to 5 seconds delay. Sometimes on switch click light turns on an instance but if i pressed same button again it will turn off only after 5 sec. So in such situation conbee can not be used because you must stay near switch and wait if you will need to press again.
After searching for similar issues here, i put conbee with 1m usb extender cable, conbee changed to use channel 25, wifi AP changed chanel to 1 and other AP to 6 but nothing helped. deCONZ shows that conbee firmware is up to date.
Also tried use HassOS pre v5 and boot on USB SSD but issue still persist.
What else i can try? plese help. in such situation conbee is useless.
