Conbee II disappearing
Hi All
Trying to figure out if my conbee II is doa. Plugging it into a NUC running hass.io .101.3 on Ubuntu.
I tried the deconzeplugin but the stick kept losing connection to it.
Ls on the /Dev folder and ttyacm1 appears and disappears at about 20s intervals.
Connected direct as well as via USB extension (tried 2) and have removed my aeotec stick from tty0 as well.
Any suggestions or should I return and try a new one.
I have several aqara buttons that I would like to hook up.
Thx
It appears that you need to downgrade the firmware as the current version is causing some issues in certain situations. The only issue with this is that deConz will update it again.
I am trying to find out how to stop the auto update feature in deConz so that I can keep on the older version on it.
