Hello All,
I have the following errors suddenly appearing:
Logger: homeassistant.components.zha.core.gateway
Source: components/zha/core/gateway.py:172
Integration: Zigbee Home Automation (documentation, issues)
First occurred: 1:56:51 PM (12 occurrences)
Last logged: 2:04:36 PM
Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 1 of 3)
Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 2 of 3)
Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 3 of 3)
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 172, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 144, in new
await app.startup(auto_form=auto_form)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 125, in startup
await self.initialize(auto_form=auto_form)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 110, in initialize
await self.permit(0)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 929, in permit
await zigpy.zdo.broadcast(
File "/usr/local/lib/python3.10/site-packages/zigpy/device.py", line 518, in broadcast
return await app.broadcast(
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 744, in broadcast
await self.send_packet(
File "/usr/local/lib/python3.10/site-packages/zigpy_deconz/zigbee/application.py", line 419, in send_packet
raise zigpy.exceptions.DeliveryError(
zigpy.exceptions.DeliveryError: Failed to deliver packet: <TXStatus.MAC_CHANNEL_ACCESS_FAILURE: 225>
and then
Logger: homeassistant.config_entries
First occurred: 1:56:59 PM (4 occurrences)
Error setting up entry ConBee II - /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2477386-if00, s/n: DE2477386 - dresden elektronik ingenieurtechnik GmbH - 1CF1:0030 for zha
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 365, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 112, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 185, in async_initialize
raise exc
Thanks for any and all help. None of this makes sense as to what the problem actually is. I am using RPi 4 and M.2, not sure if that makes a difference.
