Good morning
Moved my ConBee II USB stick form a RPi4 test installation to a fresh setup, also on RPi.
When I plug the stick in it gets recognized and I can select to install ZHA mit deConz with /dev/ttyACM0.
But it can’t then communicate with the ConBee II stick with following error in the logs:
Logger: zigpy_deconz.api
Source: components/zha/radio_manager.py:178
First occurred: 10:15:09 (2 occurrences)
Last logged: 10:33:56
No response to 'Command.read_parameter' command with seq id '0x02'
Source: components/zha/config_flow.py:258
First occurred: 10:15:19 (2 occurrences)
Last logged: 10:34:07
So why would it won’t work anymore on the same platform with the same HA version?
The stick has been reset several times with the phoscon app on my PC…
Also when I install deConz add-on in HA the phoscon app won’t recognize the stick…so something in HA causes this problem.
